Home > Maintenance & Mods (L322) > TDV8 4.4 oil filter wrong part?
JayGee
The new Mahle OX153/7D2 is not the same as the one in there
Seems about the same overall length but when fitted to the filter housing it sticks out about 10mm more. Refitted the old filter for now. 2012 TDV8 Vogue (L322)
Post #620052 15th Jan 2022 2:14pm
Baltic Blue
I am always surprised by how much the filter on the right in your photo sticks out of the bowl , but I have used that type many times and it always works fine when torqued down to 27 Nm.
Mike
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #620055 15th Jan 2022 3:05pm
DrRob
Yep. I spotted that. Left is oem. I fitted a Mahle. Lots of us have. No issues Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #620056 15th Jan 2022 3:06pm
JayGee
Thanks. Does the filter housing adjust to the different lengths via the torque setting?
Old filter only has 4k miles on it as I changed the oil due to the service indicator which I’d presumed the garage had forgotten to reset but after doing this in my GAP IID I’m still getting service due on the dash? 2012 TDV8 Vogue (L322)
Post #620071 15th Jan 2022 4:25pm
Baltic Blue
The spring tensioner is in the bottom of the housing.
Mike.
Are you sure you are resetting the service warning correctly ?
Post #620077 15th Jan 2022 4:37pm
JayGee
I’m guessing the flow of oil is up the centre and drains back down the sides? 2012 TDV8 Vogue (L322)
Post #620082 15th Jan 2022 4:46pm
JayGee
Ah - will repeat with engine off (which is easier now I have a new battery)Thanks! 2012 TDV8 Vogue (L322)
Post #620105 15th Jan 2022 7:03pm
