Home > Technical (L322) > Gm 5L40E direct clutch hub length - DIY rebuild
BGardiner
United Kingdom 2003 Range Rover Vogue Td6 Buckingham Blue
Hi, following on from my last post, I have taken on the challenge of a diy rebuild of the GM 5l40e gearbox in my 2003 TD6 Range Rover. The box was professionally rebuilt 2years/10k miles ago - and has failed with the same problem again. I've stripped the box and the direct clutch hub has unravelled - again!
I have contacted JPAT who list two - one us 191mm long - the other 194mm - can anyone confirm the correct length please (praying RRPhil is looking 😁). They can't get the 194mm hub - so if it is that one, the box is for the scrap unfortunately.
I am taking photos and will produce a write up once I'm done
There is a fantastic write up by RRPhil that shows the disassembly process and that has been invaluable - so my thanks if you read this!
Post #619441 10th Jan 2022 10:42am
dhallworth
Hopefully you can get the bit you need to save scrapping the whole gearbox.
If a used one has failed after 10k it's probably not worth trying again with another use one I guess.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #619471 10th Jan 2022 5:00pm
BGardiner
I've measured what's left of the shaft - and it's 191.5mm long - so think it's looking good for the shorter drum. It's really bizarre why this shaft would fail as they do. I've had chance to really look at the workings of the Box, and it would appear to me that this shaft doesn't have any load until 4th or Overdrive (5th) is engaged?
My main concern is have I just been unlucky in having two fail - or is there something further down the drive train causing it? My driving style of my truck can be best described as extremely sympathetic giving I understand the cars weaknesses!!!
Post #619472 10th Jan 2022 5:33pm
RRPhil
If the measurement that JPAT are specifying is between the washer face and the end of the shaft, then I measure it at 190.71mm.
This component is from a 2003 Range Rover transmission.
I can send you the drum/shaft to look at, if you want to compare it to (what’s left of) yours?
Phil
Post #619514 10th Jan 2022 10:33pm
BGardiner
Many thanks for taking the time to do that Phil. The shaft seems to have unravelled outwards rather than length ways (Score marks from the failure - and casting/manufacture marks provide a good reference) - so I've got confidence that's the right part.
I will create another thread over the weekend that details my progress. Your posts (including the multi-part teardown) have been absolutely invaluable, and I wouldn't have taken on the job without them - so thank you for those. I've blown up to A3 the working diagrams from JPAT and they have been an excellent reference as well.
So far - the hardest part of the job has been removing the electric plug on the transfer box (was stuck solid)! The most challenging has been safely removing the centre o-ring in the gearbox. Fortunately I had a set of tyre levers that were a perfect fit - although it took some time for me to realise that!
Once I had identified that there doesn't seem to be any contamination in the clutch plates, I haven't disturbed any of the piston seals. The clutch packs that do easily come apart were all clean and still like new (to my eyes anyway!).
I am taking the opportunity to have the valve block reconditioned with Sonnax valves as I plan on keeping the car, so trying to do the job right. The company you have previously recommended (Valve Bodys UK) who are doing the Valve Body, are also flushing the Torque Converter so I know that's clean as well.
Keeping fingers crossed for a simple reassembly.
Post #619527 11th Jan 2022 7:58am
