Home > Technical (L322) > Gm 5L40E direct clutch hub length - DIY rebuild |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3067 |
Hopefully you can get the bit you need to save scrapping the whole gearbox.
10th Jan 2022 5:00pm |
BGardiner Member Since: 21 Dec 2021 Location: Cumbria Posts: 6 |
10th Jan 2022 5:33pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
If the measurement that JPAT are specifying is between the washer face and the end of the shaft, then I measure it at 190.71mm.
10th Jan 2022 10:33pm |
Many thanks for taking the time to do that Phil. The shaft seems to have unravelled outwards rather than length ways (Score marks from the failure - and casting/manufacture marks provide a good reference) - so I've got confidence that's the right part.
11th Jan 2022 7:58am |
