Home > Maintenance & Mods (L405) > JLR Warranty
nbunney
JLR Warranty
Just had my 2014 car in for the extended warranty inspection and guess what, it failed. Rolling Eyes
Service light, I know it needs an oil change, so no issues.
ACE fluid pipes leaking, apparently all of them Confused but £537.61 to sort doesn't seem that bad, as fluid is about £85. But going to get my Indie to have a look next week, when he does the oil change and service light re-set.
And now for the sting in the tail.
Exhaust centre section heatshield loose: £5729.51 Censored
Apparently it needs a DPF an possibly ACT and some other pipes and bolts.
So that figure is worst case, but even so.
Anyone else had a loose heat shield?
Again going to get my Indie to investigate and get the welder out I think.
Post #619416 10th Jan 2022 7:59am
They need to drop the exhaust and your bolts will look like they have been under water fitted to the Mary rose by the time the car is 5yrs old! Literally will be held together by the rust from where the bolts/nuts once were!
Ask your MD for some pics of the exhaust fittings sir 🙏
Post #619426 10th Jan 2022 10:02am
Kot
Re: JLR Warranty
Are you saying the DPF is missing?? how did it ever pass its MOT's? 2018 SE SDV8 4.4 Byron Blue
Post #619439 10th Jan 2022 11:27am
Mikey
Its a heatshield around the DPF
Obviously, the dealer won't be able to repair it, and it needs replacing Rolling Eyes
Find a decent specialist, and you can save yourself about £5,700 of that cost Whistle
Post #619455 10th Jan 2022 2:07pm
nbunney
Don't worry, it's off to the Indie next Monday.
I've pre-warned him to get the welder ready Thumbs Up
Post #619459 10th Jan 2022 3:07pm
