Home > Maintenance & Mods (L322) > I assume my plenum is fubar?
Chrali
Hi Guys,
I've always though my L322 smelt of diesel fumes a bit, but when removing the engine cover to undo the drivers side air intake pipe to change the air cleaner, I was confronted with this.
Is it safe to say that this is Censored and a new one is needed? I don't get any RP issues, just some smells, and (to me) underwhelming performance. I mean could it be messy oil changes, to have all that mess pretty much all around the plenum?
 Encourage alternative fuels, use all the petrol!
2012 Range Rover Vogue 4.4 TDV8
2006 Mercedes GL420 CDI
2006 Porsche Cayenne Turbo S
2006 Jeep Commander 3.0 CDI with GDE HOT Tune
1997 Nissan Patrol 4.2 GRSE
1995 Vauxhall Monterey Diamond 3.2 v6
1994 Range Rover 4.2 LSE Beluga Black, Softdash, Brooklands Body Kit - Loved it!
1993 Range Rover 4.2 LSE ended up converted to 300tdi
Post #619368 9th Jan 2022 7:25pm
JayGee
New part £500. You could try repairing it with some pop rivets along the seam ( mine has this and isn’t leaking) 2012 TDV8 Vogue (L322)
Post #619377 9th Jan 2022 8:38pm
Chrali
Ah is that confirming it fubard then? Time to see if the place I bought it from is feeling helpful, otherwise is Big Cry time. Encourage alternative fuels, use all the petrol!
Post #619403 9th Jan 2022 11:21pm
t5pete
https://www.ebay.co.uk/itm/RANGE-ROVER-4-4...635-2958-0
Maltings have them in stock
Post #619415 10th Jan 2022 6:57am
t5pete
These look to be a pattern part with throttle body
https://tpuk.net/range-rover-4-4-tdv8-air-...sport.html
Post #619418 10th Jan 2022 8:02am
JayGee
Not is stock at the last link ( otherwise I'd be tempted just to avoid cleaning mine) 2012 TDV8 Vogue (L322)
Post #619425 10th Jan 2022 8:59am
t5pete
In stock on there eBay listing
Post #619432 10th Jan 2022 9:34am
JayGee
Says 'this item is out of stock' on the yellow header. 2012 TDV8 Vogue (L322)
Post #619434 10th Jan 2022 9:36am
cass
"Ah is that confirming it fubard then? Time to see if the place I bought it from is feeling helpful, otherwise is Big Cry time."
Have you just bought this recently?
If so that amount of accumulated muck is all the evidence you need that it was sold to you with an existing fault which will help your case.
Post #619438 10th Jan 2022 10:22am
Chrali
Yup only had it a couple of months. The dealer has accepted responsibility Very Happy , so looks like I can save my pennies for now. Encourage alternative fuels, use all the petrol!
Post #619440 10th Jan 2022 10:31am
mjdronfield
The performance should definitely not be underwhelming.
Hopefully you will get it sorted and notice a change.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #619443 10th Jan 2022 10:45am
klj
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
I managed to extend the life of mine with epoxy for a good few months but , with hindsight, I should have renewed it ages back. A few days back got one from Maltimgs and sorted it. Result = soot levels low, better mpg, smooth power yield and peace of mind. The gunge in the old one and the throttle body was staggering . 60plus k miles and no supermarket diesel used. I reckon a good 5% plenum volume occupied by gunge. ----------------
2010 RR tdv8 3.6 ( gone but not forgotten ...)
2012 RR tdv8 4.4
2004 RR 4.4 V8 (M62) -gone but not forgotten (sob)
1998 P38 RR - least said the better
2009 BMW 7 Series 3.0d
Various motor cycles - BMW GS
1998 Jag XKr 4.0 V8
Post #619516 10th Jan 2022 10:36pm
JayGee
Buildup of black gunk seems to be a normal condition for these intakes even when working correctly. Even if you clean or replace the plenum to remove this build-up there will be still deposits within the manifolds and around the intake valves which you can't get to without a significant teardown of components. It's a good idea to regularly clean the MAP sensor as when this gets blocked it definitely caused a bit of hesitancy on low end pickup and maybe also remove the throttle body to ( carefully) clean this and the EGR pipe that sticks into the Plenum. Also just how long before it gets a new coat of gunk when you have cleaned it. I was watching my EGR valve position and operation via the GAP IID tool and cruising on the M-way it's open most of the time and only closes on fairly hard acceleration and overrun. 2012 TDV8 Vogue (L322)
Post #619535 11th Jan 2022 9:16am
klj
👍🏼 Thanks for info ----------------
2012 RR tdv8 4.4
1998 Jag XKr 4.0 V8
Post #619570 11th Jan 2022 2:38pm
JayGee
This seems to be working on mine
Post #620050 15th Jan 2022 2:08pm
