Home > Technical (L322) > Battery Drain issue causing me some headaches
ASH
United Kingdom 2011 Range Rover SE 4.4 V8 Santorini Black
Hi Guy's, please bare with me as I might sound a little stupid.
Ive got a battery drain on my 2011 l322 (4.4TDV8)
Ive plugged it in & got some live data & was after some advice of someone with a bit more knowledge
When the car is running I get the voltage at14.9v and 1 amp current
Switch the car off & I get the battery at 12.10v and -18a (assuming that some modules are still drawing a current)
Leave fort 40 minutes to allow everything to shut down & get 12.2V and -2a
Am I right in thinking that the -2a is still to much as a drain on the battery?
I would welcome any feedback / ideas
Many thanks in advance
Post #618548 3rd Jan 2022 12:37pm
Pjtaroni
You need to do a proper drain check and then you can start to diagnose where it is coming from. I’m sure a search on here will give you some pointers on where to start.
Post #618555 3rd Jan 2022 2:18pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Have a look here, I’m currently chasing one too but as yet no answer.
https://www.fullfatrr.com/forum/topic61968.html
Might give you some ideas though, a 2 amp draw when asleep is way too much Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #618567 3rd Jan 2022 3:40pm
ASH
Ive done the drain test from the battery & it's showing as 0.01A, which from what I can work out is ok.
if the alternator diode was knackered, would this show as a draw on the millimetre?
Ive ordered a new battery which will eliminate that
Thanks in advance
Post #618874 5th Jan 2022 3:18pm
roverberry
Norway 2005 Range Rover Vogue 4.4 V8 Java Black
The wipers for the headlight is a common sinner in that area..
Post #618970 6th Jan 2022 12:49pm
CS
My 2012 WM drained its battery twice, in both cases due to a software fault, one to do with locking and the other to do with the fuel burning heater. In each case the battery was fully discharged and needed to be tested when fully recharged to see whether it could still hold charge. The first time no, so replaced under warranty, the second time yes.
So you might want to check for software faults, in my case this was done by the dealer under warranty. Only Range Rovers since 1988
Post #619026 6th Jan 2022 7:02pm
Pedenjohn
Northern Ireland 2003 Range Rover HSE Td6 Zambezi Silver
I have a car there with an intermittent drain. And so i think it’s going to be very hard to diagnose. But I fitted one of those battery brain devices in the mean time until I can work out what’s causing it. I figure if I drive the car I can work out maybe what scenario leads to the drain and perhaps find it. Wife got in the car this morning and it had switched the battery off, hit the key fob, the battery turned on and away she went, no drama. Definitely for the £150 seems like it will save a bit of hassle with jump leads and destroyed battery’s… but I will admit I’d much rather cure the problem than work round it… but you got a do what you gotta do.
Post #619295 9th Jan 2022 12:45pm
