![]() | Home > Technical (L322) > Heater fan not working |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
And to top it off for the life of me I can’t find the fuse mentioned in the hand book for the front blower motor can someone tell me where it is pleasev 2012 Range Rover Westminster 4.4 TDV8
Anyone able to help I’m stuck with this one 2012 Range Rover Westminster 4.4 TDV8
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
I can only speak of earlier cars however it's possibly the same on the 2010/2012 cars. The final stage resistor can cause the fan to act erratically including not at all. See the video in the link, ignore the left side steering wheel, its in the same place for the RHD. 2007 TDV8 VSE
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Mine stopped working once and then started working again. Odd eh?
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 903 ![]() ![]() ![]() |
My advice would be to make sure you exhaust every alternative before undertaking fan replacement.
Thanks for the replies, unfortunately its not great news, on the 2012 there is no mention in the handbook or any of the fuse boards for the front blower fan fuse or relay which is dammed annoying i pulled all the fuses for the rear and everything is ok, so i got a new genuine FSR and swapped it, and still nothing |
If I’m not mistaken the front fuse board for 2002 to 2012 cars are the same ( ? ) in which case you need to look at Fuse 34 7.5A. It’s marked Airconditioning, Blower. Front windscreen.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Fuse 64 somewhere then…..
Fuse 34 in my car has a symbol for the petrol / diesel pump so im assuming its the filler cap fuse Thanks for the info though 2012 Range Rover Westminster 4.4 TDV8 2006 Discovery 3 HSE 260k miles and still going strong with a new owner |
picture is my dash but fuse 64 in the cjb which im assuming s the one in the dash is in my car is for dvd which is there but u dont have a dvd but when i did a search online for 2012 fuse box i get this image that clearly shows fuse 64 but i dont have this fuse board ![]() im bloody confused as i cant find any reference to a fuse in any of the three locations for the front blower and there must be one 2012 Range Rover Westminster 4.4 TDV8 2006 Discovery 3 HSE 260k miles and still going strong with a new owner |
To simplify matters just check every 5A and 7.5A fuse on the front fuse board, there aren’t that many. |
ill give it a go thank you 2012 Range Rover Westminster 4.4 TDV8
Puller them and all good 2012 Range Rover Westminster 4.4 TDV8 2006 Discovery 3 HSE 260k miles and still going strong with a new owner |
That’s a pain then. The screenshots were from the 2010 2012 Workshop Manual….
