Home > Technical (L322) > Heater fan not working
Just to sure now l personally would check every other fuse. Smile
Post #619148 7th Jan 2022 9:04pm
Unintentional echo. Very Happy
Post #619149 7th Jan 2022 9:04pm
mjdronfield
Any further help?
https://www.fullfatrr.com/forum/post477526.html
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #619152 7th Jan 2022 9:14pm
johnboyairey
not sure its relevant, but my 2012 came with a missing fuse in the rear boot right stowage panel, the forth one from the right, 15 amp was missing, I replaced it and the rear blower fan spun up continuous, with ign. off. so I diagnosed/guessed it was the rear FSR hedgehog. and I had a spare, so dropped it in under the console cubby box, and all is well. but as mentioned, it was a 15 amp blue. fuse.
Post #619157 7th Jan 2022 10:28pm
Brerfox
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
hi I've just replaced mine, wasn't toobad a bit fiddly but no cutting involved. I checked every fuse and then replaced the hedge hog which we do have. and then replaced the fan. there is a video on how to take the dash out, difference is you have to take both side vents out and also both glove boxes have to come out remember not to close them when you disconnect the power my tip would be to buy a small screwdriver set the one with a bendy wand type thing. oh and the fan new of eBay £40
Post #619260 9th Jan 2022 1:12am
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Hi Brerfox that sounds promising do you have any more info on things I need to do, I’m good with spanner’s but it’s the takingbthe dash out I struggle with so all the info / tips you can give would be a great help 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #619296 9th Jan 2022 1:17pm
