Home > Technical (L322) > Strange behaviour on motorway
jazzdude
Cyprus 2007 Range Rover Vogue TDV8 Java Black
3.6 tdv8. Setting the cruise control at 120 km/h, on the slightest incline the car shifts down from 6th to 5th.
Putting it in manual mode and selecting 6th, it will comfortably go up and down any slope without a problem around 2k rpm.
I'm running 285/45/22s, is this messing with the gearbox ratios or can it be something else? Gearbox oil was changed last year by the previous owner apparently.
Post #618485 2nd Jan 2022 8:29pm
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Although mine is a TD6 it does the same - on cruise it will often downchange & then back up again but without cruise it will stay in top, on the same bit of road at the same speed.
Post #618512 3rd Jan 2022 8:12am
jazzdude
I found another thread on exactly the same issue and it seems that on cruise control this dropping of a gear is common. It seems that the car tries to keep the speed more constant by dropping to 5th even on the slightest incline, even though its so annoying.
I guess I'll just keep it in manual to stop that happening.
Post #618513 3rd Jan 2022 8:28am
