![]() | Home > Technical (L322) > Oil on RH turbo |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Could be the inlet manifold/cam cover gasket leaking 2007 TDV8 VSE
jazzdude Member Since: 16 Oct 2021 Location: Limassol Posts: 26 ![]() ![]() ![]() |
This is what it looks like.
If it is the inlet manifold gasket it is a big job to change it. My left side is leaking and I will change it in a couple of weeks when I have a couple of clear days. The RH is apparently harder than the left. You can see if it's leaking by removing the metal acoustic cover, which in itself is a pain to get off. The oil soaks into the soundproofing until it's saturated and lets go of a big drip. 2007 TDV8 VSE
