Home > My Range Rover > New owner of a forum members car! |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
I have that wind noise and I think it’s tyres as it varies with speed and surfaces.
2nd Jan 2022 10:22am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3141 |
The Squeak may be the water pump. The front spindle is notorious for the bearings going. Easy to check. Justgrab the front spindle and see if it moves around. Easy and cheap to change. |
2nd Jan 2022 10:40am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Fair point on the tyres.
2nd Jan 2022 11:24am |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 654 |
Heres a tip on how to peel off the blue tint from the rear screen. Pull it from one corner down and use a hair dryer or heat gun on a very low setting when you get to the heating elements, this will soften up the adhesive and pull the tint film slowly along as you are heating it up. However, that might seem easier than done, because depending on how long it's been on there, the chances are the film will just keep snapping every inch of so. Once all removed, use tar and glue remover to get rid of the sticky residue and you should end up with a nice clean and clear window. Hope this helps. |
2nd Jan 2022 11:25am |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 |
Thanks for the above will start checking water pump tomorrow, as it’s raining here and I’ve been tasked with clearing the garage as the SIII is due back this month!
2nd Jan 2022 12:19pm |
Right, had another drive and look around, would this be the source of the wind noise? And does anyone know the part number for the missing part:
2nd Jan 2022 2:52pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Not sure if compatible, but I have just replaced my water pump with a new one while the engine is stripped. It was a proactive maintenance task. Now it’s out and I’ve had a look, it seems to be in good working order. It’s from a 4.4 tdv8 and will be posted in the for sale section in the coming weeks… so if it’s of interest then shout. EDIT: ah, just reread your post and see you have the td6 so it’s unlikely to be compatible. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
2nd Jan 2022 3:21pm |
Started raining so sellotape covered it over for the moment!!!!
2nd Jan 2022 3:50pm |
That's what I mentiioned in my post earlier.
2nd Jan 2022 5:55pm |
Hi Richard, apologies I misunderstood! I’ve ordered the push fit part, if it doesn’t click in I’ll try and workout the missing fitment. Is there a workshop manual that is recommended with the blow out diagrams? |
2nd Jan 2022 6:07pm |
Hi bud
2nd Jan 2022 6:15pm |
Having another thought, perhaps the part you ordered is the complete bit, difficult to tell from the part diagram searching fromyour part number Cheers
2nd Jan 2022 6:21pm |
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 61 |
I had the same rear left window fault on an X5 which is a similar Bmw part and it required a new switch .
2nd Jan 2022 9:11pm |
Tswitch Member Since: 24 Jan 2020 Location: Derby Posts: 12 |
Wind noise is probably a missing foam block, there should be two either side when bonnet lifted near scuttle/ windscreen.
2nd Jan 2022 9:35pm |
