Home > My Range Rover > New owner of a forum members car!
Slow progress
So finally purchased my first FFRR from this forum last week. Toms Epsom green L322 td6.
Initial thoughts are we love it, and whilst it’s no garage queen it’s perfect for us, it drove from Glasgow with no issues the 285miles back with no issues. Average 29.1mpg
So plans are as follow;
1. Full service inc. gearbox and diffs. Also brake fluid change as I can’t find a record of it being done.
2. Change brake pads as they were the only advisory. Are Ferrodo or Green Stuff recommended? Or another brand?
3. Peel blue tint film off the windows. One question here, will peeling it off damage the rear screen heating elements?
4. Find a body shop for the rusty arches, and open Pandora’s box by getting the silk covers an rear arch liners removed to see what’s lurking.
5.Leather repair to the drivers seat (see attached)
In addition we’ve 2 noises I can’t identify and hoped you might be able to identify:
1. A squeak that increases with speed , sounds like it’s something rotating, so perhaps a bearing or something on the drive shaft??
2. Wind noise in the drivers side above 35mph. It sounds like the window is open but no air ingress and the windows and doors are definitely shut.
Post #618385 2nd Jan 2022 9:46am
DrRob
I have that wind noise and I think it’s tyres as it varies with speed and surfaces.
What state are the tyres? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #618390 2nd Jan 2022 10:22am
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
The Squeak may be the water pump. The front spindle is notorious for the bearings going. Easy to check. Justgrab the front spindle and see if it moves around. Easy and cheap to change.
Post #618393 2nd Jan 2022 10:40am
rjff
Fair point on the tyres.
ISTR seeing a comment or two about the plastic scuttle at the bottom fo the windscreen causing a noise if it is loose , deformed or a fixing is missing. This allows it to raise alittle causing a wind noise. Cheers
Richard
Gap IIDBT
Post #618404 2nd Jan 2022 11:24am
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Heres a tip on how to peel off the blue tint from the rear screen. Pull it from one corner down and use a hair dryer or heat gun on a very low setting when you get to the heating elements, this will soften up the adhesive and pull the tint film slowly along as you are heating it up. However, that might seem easier than done, because depending on how long it's been on there, the chances are the film will just keep snapping every inch of so. Once all removed, use tar and glue remover to get rid of the sticky residue and you should end up with a nice clean and clear window. Hope this helps.
Post #618405 2nd Jan 2022 11:25am
Slow progress
Thanks for the above will start checking water pump tomorrow, as it’s raining here and I’ve been tasked with clearing the garage as the SIII is due back this month!
Tyres are all the same Pirelli Scorpions (not verdes) and all fitted in the past 12months, will check the tyre pressures to see if there’s any difference.
Hairdryer treatment, I’ll contact Alex Ferguson if it doesn’t work, but will give that a go on Tuesday…..when the wife is out at work😂
Post #618420 2nd Jan 2022 12:19pm
Slow progress
Right, had another drive and look around, would this be the source of the wind noise? And does anyone know the part number for the missing part:
Is this the correct part?
CYC000010
Also one amusing little gremlin…if the window lock button isn’t selected the rear passenger side window lowers off by itself! Will that be a broken switch?
Post #618440 2nd Jan 2022 2:52pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Not sure if compatible, but I have just replaced my water pump with a new one while the engine is stripped. It was a proactive maintenance task. Now it’s out and I’ve had a look, it seems to be in good working order.
It’s from a 4.4 tdv8 and will be posted in the for sale section in the coming weeks… so if it’s of interest then shout.
EDIT: ah, just reread your post and see you have the td6 so it’s unlikely to be compatible. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #618442 2nd Jan 2022 3:21pm
Slow progress
Started raining so sellotape covered it over for the moment!!!!
Assuming it’s just a push fit part? Ordered the CY000010 part.
Post #618449 2nd Jan 2022 3:50pm
rjff
That's what I mentiioned in my post earlier.
I think the part is what you want but there msut be a part to fix it into which may need replacing. You'll have to search for that too. Cheers
Richard
Gap IIDBT
Post #618472 2nd Jan 2022 5:55pm
Slow progress
Hi Richard, apologies I misunderstood! I’ve ordered the push fit part, if it doesn’t click in I’ll try and workout the missing fitment. Is there a workshop manual that is recommended with the blow out diagrams?
Post #618475 2nd Jan 2022 6:07pm
rjff
Hi bud
You may be able to find the info/drawings in the microcat sections in the Wiki (top right on the page under the FF logo).
Failing that perhaps Paul Redding at Advanced Factors can help. They're a site sponsor and I and other have found him great on customer service. May not open up again until Tuesdsay though.
HTH Cheers
Richard
Gap IIDBT
Post #618478 2nd Jan 2022 6:15pm
rjff
Having another thought, perhaps the part you ordered is the complete bit, difficult to tell from the part diagram searching fromyour part number Cheers
Richard
Gap IIDBT
Post #618480 2nd Jan 2022 6:21pm
Andra
I had the same rear left window fault on an X5 which is a similar Bmw part and it required a new switch .
Switch is easy to remove and unplug to avoid mishaps while waiting for a new part .
Post #618494 2nd Jan 2022 9:11pm
Tswitch
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Wind noise is probably a missing foam block, there should be two either side when bonnet lifted near scuttle/ windscreen.
One on bonnet one on wing. They were fitted to stop wind noise
Post #618495 2nd Jan 2022 9:35pm
