Home > Maintenance & Mods (L322) > Remote heater remote upgrade.
daveturbo
I would like a remote heater fob ,for my 2011 range rover vogue,4.4tdv8. Not sure which one i would need and any control units needed ,hope you guys can point me in the correct way. Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #614753 4th Dec 2021 7:54pm
Sonearly
Hi
You need remote type either T90 or T91, T91r will not pair with your vehicle. If you remove the rear storage panel you will see a small box which will have T91 printed on it. They all left the factory with the receiver fitted. Enter FBH in the search field, plenty of info available on here.
Post #614773 4th Dec 2021 9:45pm
Nismotec
You can always remove the control unit and replace it with a GSM switch which you can then activate via your mobile phone by either calling it or texting it. Ive done it to mine and it works a treat... And because its mobile phone network, the range is far superior to the IR remote fob .
Post #616394 14th Dec 2021 10:18pm
darrenm
Sonearly wrote:
Hi
my 2010 has the t91 remote and my wifes 2012 has the t91r
Post #617871 29th Dec 2021 11:32am
Sonearly
Really is a minefield. Other posts have stated that although Marked as T91r late L322 vehicles have only been able to pair with T91 remotes. Although as previous post it appears some MY12 cars have transitioned to T91r fully. But from personal experience, my previous early MY11 fitted with T91 receiver worked with both T90 and T91 remotes. MY current later MY11 car also is the same and will not pair with T91r remote. Would be great if there was actually some information as to what Vin numbers the transition to T91r actually happened.
Post #617888 29th Dec 2021 12:49pm
