![]() | Home > Maintenance & Mods (L322) > Remote heater remote upgrade. |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Hi
Nismotec Member Since: 27 Apr 2019 Location: Dorset Posts: 54 ![]() ![]() |
You can always remove the control unit and replace it with a GSM switch which you can then activate via your mobile phone by either calling it or texting it. Ive done it to mine and it works a treat... And because its mobile phone network, the range is far superior to the IR remote fob . |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 185 ![]() ![]() ![]() |
# my 2010 has the t91 remote and my wifes 2012 has the t91r |
Really is a minefield. Other posts have stated that although Marked as T91r late L322 vehicles have only been able to pair with T91 remotes. Although as previous post it appears some MY12 cars have transitioned to T91r fully. But from personal experience, my previous early MY11 fitted with T91 receiver worked with both T90 and T91 remotes. MY current later MY11 car also is the same and will not pair with T91r remote. Would be great if there was actually some information as to what Vin numbers the transition to T91r actually happened. |
