![]() | Home > Technical (L322) > TD6 STARTER MOTOR |
Sounds like a 30 minute job at the local Indy and £50 + VAT.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
i dont think anyone has done it here ..sounds fairly easy, dis-connect battery , undo the starter motor bolts and remove...let us know how you do/did it .. |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Yep - sound simple - until you look and see where it is located |
Right - finally changed the starter motor - what a pig of a job !
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
Sounds like a sh#t of a job Hope I never have to do. But then Its not as bad as the new Toyota TDV8. Starter moter is inside bellhousing that has to be split. $14000 in done at a garage. About $10000 (not sure what that is in pounds[gbp 6400 ???]) just for the starter moter so Ive been told
found on rave that the oil dip stick holder can be removed to make the job a bit easier, i know its a bit late now, sorry mate.. ... - .- -.
I've looked for the pipe thats not connected but on Rave I cannot find any info + after viewing 4 pages it automatically reverts back to the front info page ? Also it's only the NAS 4.4 engine |
Another starter bites the dust |
thats bad news mate, at least this job should go quicker now you've done one already.. |
Yep - I certainly hope so - and the fact that it doesn't rain |
Removed old and fitted new starter motor on Friday evening to beat the rain.Took 30 min's start tnow working superb |
now we know who to come to to do ours.. |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
The pipe you are talking of i think comes from the vac pump its to do with the active engine mounts fitted |
Thanks for that - it certainly comes from the engine mounts but I can't seem to find where it connects on to |
