Home > My Range Rover > L405 newbie questions!
nickt68
2015 Range Rover Vogue SE SDV8 Santorini Black
It’s nearly getting to the point that I might have to look at the bloomin manual!
Can any of you help please:-
1. Should the indicator and wiper stalks be illuminated?
2. Is the screen wash (squirters) meant to be a fine mist or are they blocked/damaged - my L322’s had full on jet blast but the new one doesn’t seem as powerful
3. Did I read somewhere that the rear camera has a spray wash to clean it?
4. Mine’s a 2015MY SDV8 SE and I thought from that model year that it should have the auto access mode. It doesn’t seem to work automatically but does using the button on the drivers door.
5 Speed alarm - in my last L322 there was an option to have a speed alarm which I had set at 75mph as I drive daily on the camera infested M1 and M25. It would ‘bong’ when you hit 75 but I haven’t found this function on the L405
Happy Christmas to you all and thanks for your help!
Post #616763 17th Dec 2021 7:13pm
1JBS
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Congratulations
1. Should the indicator and wiper stalks be illuminated? Don't think so.
2. Is the screen wash (squirters) meant to be a fine mist or are they blocked/damaged - my L322’s had full on jet blast but the new one doesn’t seem as powerful - Meant to be a fine mist which should work really well.
3. Did I read somewhere that the rear camera has a spray wash to clean it? - Not on your model year on 2016 onwards.
4. Mine’s a 2015MY SDV8 SE and I thought from that model year that it should have the auto access mode. It doesn’t seem to work automatically but does using the button on the drivers door. Not on your model year on 2016 onwards.
5 Speed alarm - in my last L322 there was an option to have a speed alarm which I had set at 75mph as I drive daily on the camera infested M1 and M25. It would ‘bong’ when you hit 75 but I haven’t found this function on the L405 - not sure but cruise works really well.
Post #616813 18th Dec 2021 1:17pm
nickt68
Thanks 1JBS 👍
Post #616841 18th Dec 2021 5:59pm
mlambton
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
1. No mine are not illuminated
2.Mine is a fine mist
3. No rear camera spray (just headlights)
4.Mine’s a 2015MY SDV8 AB. I do have proximity unlocking and I believed they all had them (it was not an optional extra and the brochure for that year doesnt mention it)- I reckon you should have it
5.I have the speed alarm ASL button next to the terrain control knob
....yes the ACC is very good 2015 Range Rover L405 SDV8 AB Corris grey
2010 Range Rover TDV6 HSE Narra Bronze sold
2006 Discovery 3 SE green sold
Defender 90 td5 sold
Defender 90 soft top sold
Post #616844 18th Dec 2021 6:25pm
nickt68
Thanks miambton, I’ve got proximity unlocking too (keyless unlocking when you’re close?). Will have a play with the ASL button, thank you. Have had a quick go on the adaptive cruise and that is really weird but great 😀! Haven’t plucked up the courage to test the queue assist yet!
Post #616847 18th Dec 2021 8:30pm
mlambton
The big test (that I have not tried) is the auto braking/crash avoidance system 2015 Range Rover L405 SDV8 AB Corris grey
Post #616852 18th Dec 2021 9:12pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Auto access mode? What do I put here then?
Post #616853 18th Dec 2021 10:03pm
nickt68
GAC23 - Auto Access Mode - I may have got that wrong but think that is where the car automatically lowers into access mode as your speed drops (i.e. suspension lowers)
miambton - me neither but I have set off the hazard alarm thing a couple of time (which seems incredibly sensitive Smile Smile !)
Post #616896 19th Dec 2021 12:24pm
GAC23
Aha!
Thanks. What do I put here then?
Post #616898 19th Dec 2021 12:36pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
I'm the same. Have not yet plucked up the courage to try it. Have attempted to try it but always bottle it at the last minute (assuming you mean when the Adaptive Cruise control is on).
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #616972 20th Dec 2021 9:03am
