Home > Maintenance & Mods (L322) > Anyone know what this squeak on start up is?
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
Seems every time my car visits the local indy, it comes out with another problem!!
Post #616798 18th Dec 2021 8:31am
Range Rover L322
We have a similar sound on a 4.4 diesel. It is a belt going over a small pulley wheel - only happens on startup then goes.
My mechanic is an ex LR Chief Technician and knows his stuff. We did a belt tensioner mod earlier this year when we had the engine out. Long and short of it is (on our diesel) there's nothing wrong mechanically just a noise.... we are trying some belt dressing next.
I know ours is a diesel but similar issue!...
Post #616800 18th Dec 2021 10:00am
Adrian 15
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Totally agree with what’s been said, I had a squeaky noise and a rumbling at 45k. It turned out the bearings were shot on an idler pulley. Had the whole lot replaced with Land Rover parts and the squeak has now returned on startup and then it goes. I think it’s just one of those things on some cars. Range Rover Vogue SE 4.4 TDV8
Post #616814 18th Dec 2021 1:27pm
knwatkins
As has been said above, sounds like a belt tensioner or idler. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #616815 18th Dec 2021 1:34pm
aja500
Thank you all three of you for your comments, very much appreciated. All the issues experienced sound identical. As you say, it does go after a short while, so I won't worry about it.
Many thanks to you all once again for sharing your knowledge.
Post #616830 18th Dec 2021 3:22pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I'd get it changed either way mate. If the tensioner goes, you'll soon know about it when everything else gives up under the engine bay
Post #616835 18th Dec 2021 4:07pm
kevinp
Mine does it as well. I think the colder weather makes the belt stiffer hence the noise.
Post #616836 18th Dec 2021 4:22pm
DrRob
m
I get the same when it’s cold and damp. Goes within a few minutes. Keep us posted on the belt dressing Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #616837 18th Dec 2021 4:37pm
