Home > Maintenance & Mods (L322) > Anyone know what this squeak on start up is? |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
We have a similar sound on a 4.4 diesel. It is a belt going over a small pulley wheel - only happens on startup then goes.
18th Dec 2021 10:00am |
Adrian 15 Member Since: 14 Feb 2021 Location: Norfolk Posts: 39 |
Totally agree with what’s been said, I had a squeaky noise and a rumbling at 45k. It turned out the bearings were shot on an idler pulley. Had the whole lot replaced with Land Rover parts and the squeak has now returned on startup and then it goes. I think it’s just one of those things on some cars. Range Rover Vogue SE 4.4 TDV8 |
18th Dec 2021 1:27pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
As has been said above, sounds like a belt tensioner or idler. Kev
18th Dec 2021 1:34pm |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 824 |
Thank you all three of you for your comments, very much appreciated. All the issues experienced sound identical. As you say, it does go after a short while, so I won't worry about it.
18th Dec 2021 3:22pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
I'd get it changed either way mate. If the tensioner goes, you'll soon know about it when everything else gives up under the engine bay |
18th Dec 2021 4:07pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1215 |
Mine does it as well. I think the colder weather makes the belt stiffer hence the noise. |
18th Dec 2021 4:22pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
m I get the same when it’s cold and damp. Goes within a few minutes. Keep us posted on the belt dressing Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
18th Dec 2021 4:37pm |
