![]() | Home > Maintenance & Mods (L322) > Range Rover 5.0L Supercharged - CAM CHAIN - CAM BELTS |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 352 ![]() ![]() ![]() |
Does anyone know WHEN the
Hi Dave
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
On the Jag forums that I frequent the general consensus seems to be to listen for strange noises and rattles at start up. If you hear a rattle for a few seconds on cold start then it's worth thinking about getting the chains done.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6742 ![]() ![]() ![]() |
Oh that’s why it’s sounded rough then? |
Have you got those steps fitted yet? |
On my to do list over Christmas/New Year |
I don’t believe there is a schedule for the chains sir… Should be fitted for life or when they start to rattle which ever comes first 👍 |
Graham4242 Member Since: 26 Sep 2021 Location: Dubai Posts: 41 ![]() ![]() ![]() |
I've just "gone through this process". It started off with the clank at switch off which was the supercharger connecting piece (internal part three pin holes on each side). With that off the engine was making still making to much ticking noise. So the front of the engine came off and the the tensioner had collapsed (no longer pushing on the chain guide). There was play in the camshaft sprockets so they were replaced as well.
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
£195.00 an hour |
My car had done 150,000kms
