Home > Maintenance & Mods (L322) > Range Rover 5.0L Supercharged - CAM CHAIN - CAM BELTS
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Does anyone know WHEN the
TIMING CHAIN on the 5.0 S/C need to be replaced ?
including the
Variators x4 ( x2 Inlet & x2 Outlet ) / Cam Chain Guides / x4 Guide Tensioners / Cam Chain x2
I have a feeling its around the 100K mark ????????
I did see a YouTube film of a L405 5.0 S/C having one done at 83,987K
I also read on the web:
https://british4wdspecialists.co.nz/land-rover-cambelt/
[/quote]
As a rule of thumb timing chains are supposed to last “the life of the engine”.
The only chain system I’ve seen seriously fail is the 4.4 Range Rover BMW V8 fitted from 2002-2005. It is known to break it’s chain guides & send horrible metal swarf all through the engine, requiring a full strip & rebuild. So if you have a high mileage one of these & plan to hold onto it, give us a call to make a plan.
As far as Land Rover cambelt & replacement are concerned, British 4WD Specialists stock a good range, have all the tools & are regularly carrying out this work for our customers.
One further note on Land Rover cambelt replacement is the matter of Discovery 3/Range Rover Sport 2.7 TDV6 oil pump failure. There have been cases where the pump body has cracked after a belt change causing the tensioner to break off & the engine to lose timing (pistons hit valves etc etc). Due to the tensioner being mounted on the body of the pump, the new belt (being tighter) amplifies any weakness that already existed.
Land Rover have brought out a modified (stronger) oil pump casting & we always recommend to our customers that this is changed at the same time. It may cost a bit more, but nothing like the cost of destroying one of these engines.[quote]
so what does anyone know on this subject -
Post #616310 14th Dec 2021 11:10am
dhallworth
I don't believe there is a specific interval for the chains. They just get replaced when you start hearing them rattle, start getting a misfire or a check engine light.
Post #616320 14th Dec 2021 12:08pm
EmiratesA380
Hi Dave
Thanks for the reply - I ve asked our LR dealer - they don't seem to know also which is causing me a concern -
I think these can and do wear - everything wears at some point !
The question is how long do they last ? -
How long would the chain guides last ( Hard plastic in HOT OIL from my book in aircraft's is a no no - Cam Guides / Plastic in hot oil wear/breaks fast )
cheers fella for replying
Post #616324 14th Dec 2021 12:24pm
dhallworth
On the Jag forums that I frequent the general consensus seems to be to listen for strange noises and rattles at start up. If you hear a rattle for a few seconds on cold start then it's worth thinking about getting the chains done.
Don't over think things and just enjoy it Smile That's what I'm doing with my XFR with the same engine in it.
Post #616339 14th Dec 2021 2:21pm
Oh that’s why it’s sounded rough then? Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #616340 14th Dec 2021 2:27pm
dhallworth
Laughing 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #616343 14th Dec 2021 2:41pm
Have you got those steps fitted yet? Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #616344 14th Dec 2021 2:47pm
dhallworth
On my to do list over Christmas/New Year Smile Had hoped to do them sooner but have got a P38 dashboard removed to do the heater matrix just now instead. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #616346 14th Dec 2021 2:52pm
I don’t believe there is a schedule for the chains sir… Should be fitted for life or when they start to rattle which ever comes first 👍
Post #616372 14th Dec 2021 5:50pm
EmiratesA380
This is HOW to Replace your Range Rover 5.0L Timing Chain
https://www.youtube.com/watch?v=SZRToMeGhS0
5 Stars all round - Fair Play this guys knows his stuff, I am sure I've seen him working on our A380 units ! - He's a Ninga
Post #616447 15th Dec 2021 9:27am
Graham4242
United Arab Emirates 2011 Range Rover Autobiography 5.0 SC V8 Alaska White
I've just "gone through this process". It started off with the clank at switch off which was the supercharger connecting piece (internal part three pin holes on each side). With that off the engine was making still making to much ticking noise. So the front of the engine came off and the the tensioner had collapsed (no longer pushing on the chain guide). There was play in the camshaft sprockets so they were replaced as well.
It is a major job (way beyond my beginner spannering skills) and was considerably extended by opening Pandora's box and finding other parts that needed doing and then ordering them from the UK. Plus don't forget to allow for some coolant lines that will inevitably spring a leek once you've had them off and on.
I am very happy with the result the engine is smooth as you like and has plenty of beans.
I got the supercharger rebuild kit from Quality super chargers, timing chain kit from Turners Engineering and the sprockets from LR Parts. I don't know know if I'm allowed to post these names here but they all worked.
If your going to get this done get all of the bits first because a lot of stuff needs to come off and it falls into the 'you might as well while you're there category'. Best of luck. Current
2011 Autobiography, 2014 Vogue SE Supercharged
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #616479 15th Dec 2021 12:45pm
EmiratesA380
hey graham4242
that's great to hear - well done in getting her back together
can you tell us all the mileage
from what ive read anything from 82,000 miles ( 132,000 km ) to 120k ( 193,000 km )
i have the full jaguar landrover workshop manual which shows all the tools - local lr dealership cost parts at £3000 plus 3 days labour @ £195/hour £4095.00
total for this job around £ 6,000 to £ 7000.00 uk
what i am trying to get to the bottom is -
has anyone had this done
what mileage ?
surley every chain on the planet will stretch - no such thing as sealed for life
even the cam chain guides will wear out - plastic guides sitting in hot oil is a no no
what we always say at work is " what goes round must slow down "
but thanks graham4242 for adding to this thread - appreciated
Post #616500 15th Dec 2021 3:15pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
£195.00 an hour Shocked Shocked
Post #616514 15th Dec 2021 4:27pm
Graham4242
My car had done 150,000kms
Here’s some pictures of the job painful to look at
 Current
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #616541 15th Dec 2021 8:37pm
EmiratesA380
Thanks Graham4242 for posting
appreciated
Post #616560 15th Dec 2021 10:45pm
