![]() | Home > Technical (L322) > Adaptive Headlights & Cornering lights - standard? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
Not standard. The specs with options and prices are in the Wiki…. Top right…
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
Is there any visible difference between the two types, looking from outside? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Had the same query myself. Mines not got them, though cornering light wise… it still has the area of the headlight with the segments in etc. The only difference is that you can see LEDs in the segments on the units with cornering lights.
Here we go…
Can’t see any mention of cornering lights in any shape or form on 2011 MY, only adaptive headlights…
Thanks. I've read that.. Did you discover if you had them? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Possibly standard then.. And it's just the adaptive lights that are an optional extra. 2011 4.4 TDV8 Vogue SE - 'Black Betty' 2000 4.0 P38 HSE - 'Green Goblin' - Gone. Audi..Mini..BMW.. |
Not standard, just list Xenon with headlight wash as standard. Was the optional bit I took a screenshot of.
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 ![]() ![]() ![]() |
My understanding from the WM is that Cornering or Static Banding Lamps as the WM calls them are only available with AFS. I think when AFS is specified then they are standard.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I’ve got both dynamic and cornering lights, but I do have an autobiography with vision pack, exactly as per the spec list specified if. |
There we go then. Looks like they come as a package and are not standard, unless it’s an AB.
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 ![]() ![]() ![]() |
I’ve got both on my 07 Vogue SE 2009 (2010 MY) 5.0 Supercharged Autobiography
Might have done something different on previous model years. We are looking at 2011 VSE.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2592 ![]() ![]() |
Adaptive light option included cornering lights. |
