Home > Camping, Caravanning and Holidays > Airport Parking - Battery Drain |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4313 |
If you've never had issues before and battery is in good health then 2 weeks will be fine Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Dec 2021 11:25am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 |
As said, shouldn't be a problem. One thing to do, to avoid locksmiths, is to make sure you can unlock it by inserting the key in the lock. John
14th Dec 2021 11:45am |
misternomer Member Since: 17 Nov 2021 Location: Kent Posts: 11 |
Erm - where the heck is the lock. Mine is blanked out. Do I need to remove a blanking cover?
14th Dec 2021 1:37pm |
Pendle Member Since: 12 Dec 2021 Location: Hampshire Posts: 23 |
Hi
14th Dec 2021 2:20pm |
Ha - thanks Pendle. I have that exact same charger, along with another in my garage. Can I find the adaptor to charge either of them? Can I F%^£?
14th Dec 2021 2:37pm |
Porthbay Member Since: 18 Sep 2021 Location: Yorkshire Posts: 7 |
I have had current drain problems, still unresolved at the moment. I wanted to see what was going on so bought one of these ( only a very small drain from their usage) : BM2wireless car battery checker ( https://www.ebay.co.uk/itm/373732733079)
14th Dec 2021 9:59pm |
Or just leave your bonnet unlatched. |
14th Dec 2021 10:07pm |
Pjtaroni Member Since: 21 Aug 2021 Location: Loughborough Posts: 37 |
How about a cheap solar panel charger? Just a small one stick on the inside of the windscreen then run the cable through door shuts and clip to battery? Or in the back window and plug onto big live behind the right hand panel in bot? |
30th Dec 2021 10:13pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
What l would recommend is that you fit a battery isolating switch to the existing battery, ie the starter battery.
31st Dec 2021 9:54am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8678 |
Just so you know how to abs can see if it works
2nd Jan 2022 5:12pm |
