![]() | Home > Camping, Caravanning and Holidays > Airport Parking - Battery Drain |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4313 ![]() ![]() ![]() |
If you've never had issues before and battery is in good health then 2 weeks will be fine Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
As said, shouldn't be a problem. One thing to do, to avoid locksmiths, is to make sure you can unlock it by inserting the key in the lock. John
misternomer Member Since: 17 Nov 2021 Location: Kent Posts: 11 ![]() ![]() ![]() |
Erm - where the heck is the lock. Mine is blanked out. Do I need to remove a blanking cover?
Pendle Member Since: 12 Dec 2021 Location: Hampshire Posts: 23 ![]() ![]() ![]() |
Hi
Ha - thanks Pendle. I have that exact same charger, along with another in my garage. Can I find the adaptor to charge either of them? Can I F%^£?
Porthbay Member Since: 18 Sep 2021 Location: Yorkshire Posts: 7 ![]() ![]() ![]() |
I have had current drain problems, still unresolved at the moment. I wanted to see what was going on so bought one of these ( only a very small drain from their usage) : BM2wireless car battery checker ( https://www.ebay.co.uk/itm/373732733079)
Or just leave your bonnet unlatched. |
Pjtaroni Member Since: 21 Aug 2021 Location: Loughborough Posts: 37 ![]() ![]() |
How about a cheap solar panel charger? Just a small one stick on the inside of the windscreen then run the cable through door shuts and clip to battery? Or in the back window and plug onto big live behind the right hand panel in bot? |
What l would recommend is that you fit a battery isolating switch to the existing battery, ie the starter battery.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8678 ![]() ![]() ![]() |
Just so you know how to abs can see if it works
