Home > Technical (L322) > 4.4 TDV8 2011 - buy water in fuel sensor?
garyRR
I've had a look at the Advanced Factors site and can't see the individual cable listed.
Some fool tried re-fitting the cable to the water outlet and has damaged it's internals when I was changing the fuel filter.
Does anyone know if you can buy just to cable or a cheap assembly with the cable? 2015 Range Rover Autobiography 4.4 SDV8
Post #615200 7th Dec 2021 4:38pm
briangunn
United Kingdom 2010 Range Rover Vogue SE TDV8 Buckingham Blue
You can buy the whole filter housing (with a new cable, and filter) for a relatively sensible price.
I had the same issue, someone had broken off the terminal of the connector from the wire..
[edit] I've got a 3.6, though, I'm not sure if the 4.4 is the same - looks different.
Post #615228 7th Dec 2021 7:31pm
rjff
Gary
There is a thread o(r two) on the water sensor for the 2011on.
IIRC the part was not available as a sensor alone, but as part of the whole filter housing at about £250. A 3.6 uses the same sensor with a different housing and the assembly was £70 approx. Additionally, ISTR that the sensor may now be available at a similar cost. Sure I've seen it recently but can't recall or find it yet.
Talk to Paul Redding at AF, he's a great help. Cheers
Richard
Gap IIDBT
Post #615295 8th Dec 2021 12:21pm
rjff
May have found it.
L322 4.4tdv8 water in fuel sensor.
Search Part Number LR072685S
Try AF or Maltings Offroad. Cheers
Richard
Gap IIDBT
Post #615297 8th Dec 2021 12:26pm
kooky_guy
That's what I used on mine. I had a faulty sensor, intermittently giving me the water in fuel error. and a yellow restricted performance warning. This solved it permanently. 2010 4.4 TDV8 Vogue SE
Post #616336 14th Dec 2021 2:10pm
garyRR
I spoke to Maltings and this is what they said:
"Unfortunately, the singular part isn't made anymore and you have to buy the entire fuel filter housing assembly, of which we stock one but its about £140. The water in fuel sensor will fit both the 3.6 and the 4.4"
Since then, Maltings have started selling just the cable and sensor for £140 (basically you buy the whole housing and they only send you the cable and sensor and bin the rest).
So, I ended up buying a fuel filter assembly on ebay for a 3.6 and can confirm the cable and sensor fits the 4.4 TDV8. There's plenty on ebay for £25-30 with sensor and cable if anyone needs one and thinks £140 is a lot to fork out just for a cable.
Fitting time is 10 mins if changing the cable only and about 30 mins if changing the sensor also (which I did because the 3.6 sensor seems a better design, as it actually has a socket to guide the plug onto, which will prevent it getting damaged in future), as this involves removing the fuel filter, draining and re-fitting. 2015 Range Rover Autobiography 4.4 SDV8
Post #627964 6th Apr 2022 4:14pm
DBPFC
2010 Range Rover Autobiography TDV8 Galway Green
I bought a fuel filter assembly on ebay for a 3.6 and can confirm the cable is the same just a bit longer £25 Thumbs Up Thumbs Up
Post #627974 6th Apr 2022 5:26pm
