Home > Maintenance & Mods (L322) > 4.4 TDV8 Re-Map
Japseroony
England 2019 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Gazellio wrote:
Japseroony wrote:
Hi Gaz, how did he do it? ECU off and split or via OBD?
"Ecu has to come off...no other way.....the ecu has the 'read' funtion disabled by Bosch at the factory.
It is a 45 minute job......lid has to come off ecu.....but I have a source of new lids so no trace left of it being opened Smile "
So now we know Thumbs Up
No problem with what you have said Gaz but do you have a supply of stickers that are on the ECU as these get damaged when splitting them.
In order to split you have to heat the glue that holds the ECU together and that damages the LR stickers etc.
I think splitting an ECU on a £68k+ car is somewhat dangerous as if LR find out and by looking/driving they will, the warrantey is/could be voided and I for one dont want this so I will wait until the tool manufacturers sort out re-mapping via OBD and offering a switchable version same as the previous versions Thumbs Up "UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #58879 5th Apr 2011 11:09am
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
I thought the 4.4 TDV8 had a bolted ( 1 way ) bolt that is one use only , the people i know have managed to source the bolts in Germany. So do we have two differing ECU's ?
Chip that goes in line on the fuel rail control wiring etc , all that does is increase fueling and boost and have seen a lot of cars that over boost when these are used including one i tried on a BMW 3.0 DI , it went in the bin i am afraid. They also do not limit the torque to the gearbox that has set limiters for a reason. Far to many gone...
Post #58918 5th Apr 2011 4:36pm
"No 'splitting stickers' as you suggest....as the stickers are on the front of the ecu...."
Post #58919 5th Apr 2011 4:46pm
Japseroony
Sorry to disagree with you Gaz but the stickers are on the lid of the ECU which is the bit you are taking off and not on the body Thumbs Up
This means when you heat the lid up it damages the stickers - granted not every time but on most it does. "UNDERSTEER" ----is when you hit the fence with the front of the car.
Post #58936 5th Apr 2011 6:22pm
Japseroony
The bolts are not holding the ECU together they just stop you taking it off the vehicle or are supposed to stop you but they are readily available from LR Exclamation Exclamation "UNDERSTEER" ----is when you hit the fence with the front of the car.
Post #58937 5th Apr 2011 6:23pm
Just repeating the answers I am getting from the expert that does it..... Thumbs Up
Post #58955 5th Apr 2011 7:17pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Gazellio wrote:
No issues with checksum....uses same ecu as 3.0 Disco4/RRSport 3.0/Jaguar 3.0 TDV6
As I understood it, the reason that you couldn't reflash via OBD is because no-one had the correct checksum algorithm to make it work - if they did, they wouldn't need to split the ECU.
Post #58982 5th Apr 2011 8:57pm
AMV
2011 Range Rover Vogue TDV8 Santorini Black
I really hope we can get a sort of stealth installation soon Cool Santorini Black RR Vogue 4.4 TDV8
Post #59302 7th Apr 2011 5:37pm
diesel
United Kingdom 2010 Range Rover Vogue SE TDV8 Java Black
Trommel wrote:
I read that the issue with tuning via OBD was not knowing the checksum algorithm. It's not ChippedUK (sorry, Viezu) is it? Shocked
A few places are listing tunes for the 4.4 now, with widely different torque and BHP figures.
Hi.
Is there something I should know about Viezu?
I was looking into getting the 4.4 TDV8 re-mapped by them.
Thanks
Andy Brown
Post #61122 20th Apr 2011 11:02am
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
Hi.
Thanks
Andy Brown
Google is you're friend....
Nothing to do with the checksum. It's all down to Tricore processors and cannot be flashed via. OBD. Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #61333 23rd Apr 2011 3:52pm
Philip
They're protected by RSA signature, end result is the same.
Post #61588 26th Apr 2011 12:38pm
BigJ
Yes indeed. But one way you have to put the ECU into boot mode and flash that way, the other way is via. OBD. Two distinctly different ways of tuning. The end result is the same yes, the car is tuned. Tricore (Majority of) can not be tuned via. OBD.... yet.
Especially on a £70k motor when ECU removal can be spotted relatively easily if LR want to. Used to have:
Now have:
Post #61611 26th Apr 2011 5:00pm
