Home > Technical (L322) > 2010 L322 Glovebox Trim |
Graham4242 Member Since: 26 Sep 2021 Location: Dubai Posts: 38 |
Sorry I can’t help you with the part number but I’ve had the same issue on mine. The plastic hook that goes through the hole can be gently bent (leg of the hook) while it’s out of the hole (in its lowest position). Then guide it back into the hole. At least this worked on mine. Current
21st Nov 2021 6:23am |
tpeat12 Member Since: 18 May 2020 Location: Glasgow Posts: 69 |
Thanks Graham. I'll give it a go and maybe try softening it with some verryyyyy gentle heat. |
8th Dec 2021 7:34pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4304 |
Bend it back. Works a treat. Careful with heat. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
8th Dec 2021 7:51pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
+1 for bend it back
9th Dec 2021 12:07am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
And worked for me on several occasions... |
9th Dec 2021 12:17am |
