Home > In Car Electronics (L405) > Steering Wheel Volume Control & Streaming
nickt68
2015 Range Rover Vogue SE SDV8 Santorini Black
Hi all, have recently changed my L322 for an L405 (2015 Vogue SE SDV8). Really pleased so far...! Just wondered if anyone can help/advise on the following:-
1. Music Streaming volume - the streaming volume level is really low and to get to a similar level to the radio/cd I have to virtually double the volume level?
2. The steering wheel volume buttons do not seem very sensitive and it seems to need two pushes to start adjusting volume?
Post #614865 5th Dec 2021 3:21pm
both problems seem to be normal Nick...i find radio stations are the same with radio 2 louder than gold for instance.
my westie had an AVC [auto volume control] that compensated for the difference in volumes..
and the steering wheel up/down volume does need some clicking ... ... - .- -.
Post #614866 5th Dec 2021 3:27pm
Is the volume turned down on your phone ?
Post #614878 5th Dec 2021 4:06pm
nickt68
Thanks for the replys gents.
Alistair, I tried increasing the volume on my phone but didn’t make any difference
Stan, my L322 was just a Vogue so don’t know if it would have had the AVC but don’t remember an issue with different levels for different sources (didn’t have‘streaming’). With the L405 the radio and CD seem to be similar levels of volume but the streamed significantly lower. Sorry to hear that the steering wheel control button is normal, can’t think why anyone would think that it’s a step forward!
Post #614922 5th Dec 2021 8:36pm
number76
United Kingdom 2014 Range Rover Autobiography TDV6 Santorini Black
On your phone, there is volume, and there is BT volume!. 2014 L405 3.0 V6 Autobiography Santorini Black 49k
Post #615131 7th Dec 2021 8:53am
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I agree with Stan. Music sent via Bluetooth does have a lower volume that other sources. I was told this was a restriction imposed by Bluetooth to prevent ear damage when using headphones.
To get around the problem, I use the USB socket in the centre console box, volume via this seems to match the other sources much better.
Post #615211 7th Dec 2021 5:15pm
nickt68
number76, thanks for the reply - I’ve got an iPhone XS and have looked in settings but can’t find a Bluetooth volume setting? Can you help?!
Post #615246 7th Dec 2021 11:05pm
nickt68
millerj90, thank you too. Not tried the USB yet but would rather Bluetooth the music and turn the volume up than forever forget to unplug my phone when I get out of the car 😀!
Post #615247 7th Dec 2021 11:07pm
