Home > General (L405) > Tailgate opening from keyfob
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Pressing the open tailgate button on the keyfob opens upper and lower tailgate.
Is there a way to make it only open the upper tailgate? What do I put here then?
Post #614384 1st Dec 2021 3:41pm
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Must be, mine only opens the top Neutral
Dave Confused 2013 Range Rover Autobiography 4.4 SDV8
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #614414 1st Dec 2021 8:00pm
I'm trying to remember - I may have to go & check
There may be different behaviour depending on whether the car is locked or not....
Post #614415 1st Dec 2021 8:04pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I think it changed from only opening the top to opening both from 2015 on......
I would prefer just the top opening too.
Post #614416 1st Dec 2021 8:11pm
Yep, 13 14 only upper opens by keyfob... 15> opens both top & bottom sir... Thumbs Up
Post #614430 2nd Dec 2021 2:38am
GAC23
Thank you @Cam-Tech-Craig for the definitive answer.
There's no way of changing this I assume Sad What do I put here then?
Post #614434 2nd Dec 2021 8:27am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
My new one is a 2017 and key fob opens both top and bottom. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #614435 2nd Dec 2021 9:42am
supershuttle
If I use the key fob (on my 2013) it opens top and bottom. Geoff
Post #614455 2nd Dec 2021 3:00pm
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Mines a 14 and opens top and bottom on key Shocked Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #614534 3rd Dec 2021 8:22am
GAC23
I've been wondering whether the GAP IID lets you set this.
Going to dig around in the CCF
... which leads me to asking is there a list of it somewhere?
I've had a look but can't find it - I'm probably being daft. What do I put here then?
Post #614536 3rd Dec 2021 8:39am
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Launch 2013 AB. Only the top opened. Advised this changed late 2013/2104. Now have a 2015 AB and can confirm both bottom and top open with key fob. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #614599 3rd Dec 2021 3:21pm
cxdood
United States 2016 Range Rover HSE 3.0 SC V6 Santorini Black
My 2016 model opens both on the key fob. The button in the car itself by the drivers seat only opens the upper part. L405 2016 - Supercharged V6 petrol 380hp
Post #614952 6th Dec 2021 3:45am
AndyViking
United Kingdom 2017 Range Rover SVAutobiography SDV8 Corris Grey
My ‘67 AB opens both top and bottom on the fob 2018 SDV8 Autobiography (‘6Cool
2017 SDV8 SV Autobiography ('67)
2016 TDV8 Vogue SE ('66)
2008 D3 HSE
Post #623035 9th Feb 2022 1:02pm
Rob99
^ Ditto, but if I press the tailgate button lower right side of dash by drivers knee it only opens the top section 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #623059 9th Feb 2022 5:19pm
V8Noise
The button by your knee will only open the top but if both top and bottom are open it will close both. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
Post #623062 9th Feb 2022 5:31pm
