![]() | Home > General (L405) > Tailgate opening from keyfob |
Dave G Member Since: 30 Jul 2020 Location: Dorset Posts: 84 ![]() ![]() ![]() |
Must be, mine only opens the top |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8003 ![]() ![]() ![]() |
I'm trying to remember - I may have to go & check
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I think it changed from only opening the top to opening both from 2015 on......
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Yep, 13 14 only upper opens by keyfob... 15> opens both top & bottom sir... |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Thank you @Cam-Tech-Craig for the definitive answer.
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
My new one is a 2017 and key fob opens both top and bottom. 2017 5.0 Autobiography Supercharged
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3898 ![]() ![]() ![]() |
If I use the key fob (on my 2013) it opens top and bottom. Geoff |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
Mines a 14 and opens top and bottom on key |
I've been wondering whether the GAP IID lets you set this.
CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208 ![]() ![]() |
Launch 2013 AB. Only the top opened. Advised this changed late 2013/2104. Now have a 2015 AB and can confirm both bottom and top open with key fob. 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
cxdood Member Since: 05 Jul 2020 Location: USA Posts: 58 ![]() ![]() ![]() |
My 2016 model opens both on the key fob. The button in the car itself by the drivers seat only opens the upper part. L405 2016 - Supercharged V6 petrol 380hp |
AndyViking Member Since: 27 Oct 2020 Location: Kent Posts: 53 ![]() ![]() ![]() |
My ‘67 AB opens both top and bottom on the fob 2018 SDV8 Autobiography (‘6 |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1465 ![]() ![]() |
^ Ditto, but if I press the tailgate button lower right side of dash by drivers knee it only opens the top section 2021 D350 Fifty Edition - Carpathian Grey
The button by your knee will only open the top but if both top and bottom are open it will close both. 2017 5.0 Autobiography Supercharged
