Home > Maintenance & Mods (L322) > Left front driveshaft
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Hi,
A few weeks ago during the MOT test i had a split in the outer
gaiter on the left front driveshaft. Because the age of the car
and the so the driveshaft, I decided to renew the complete shaft.
But, after put a new Optimal shaft in, the diff started to leak.
Thought it was the seal leaking so mounted a new one.
Mmmm stil leaking, followed by a couple of not so decent words.
After this I discover the circlip between the shaft and the diff let go.
The shaft wat partly out of the diff, and that was why it was leaking.
Nothing wrong whit the seal. So put the shaft out and fitted it again
whit a new circlip.
But after a few miles, again the shaft was loose from the diff and a
Couple of mm’s out Again my wife learned a few new words.
After that I was thinking maybe I have the wrong shaft. So I stripped
the shaft again and lay it beside the old one..........you wont believe it,
the difference between the two, pulled out full, is about 50 mm!!!!
So I put the gaiters over from the new to the old one......and......
happy days, no problems anymore. Al good now, no leaks and the
shaft stays on his place.
After searching the www ..... I find
Optimal 619,5mm length thats the one I tried on
ERA. 640 mm length
Spidan. 677 mm length
GKN. 677 mm length
Official LR-OE IED500120 by GKN
So more than 50mm difference in length?? Thats a lot!
No wonder the Optimal wont fit. But stil Optimal says this is
the right shaft.
So be careful if you order a new shaft.
Regards Piet
Post #553891 14th May 2020 4:12pm
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
Not sure as I only had boots changed, shafts I think are original. Will check length though to check. Thanks for response. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #614110 29th Nov 2021 8:46am
Rom
Netherlands 2012 Range Rover Vogue TDV8 Santorini Black
Thanks Piet, nice write up 2012 4.4 TDV8 Vogue
2010 3.6 TDV8 Vogue
2003 3.0 Vogue - Gone
1998 4.6 HSE
Post #658246 2nd Mar 2023 11:08am
Gsxr1250dave
Same thing happened to a mate of mine I think the new shaft fell out when he drove it home from the mechanics workshop.
Post #658261 2nd Mar 2023 2:56pm
