![]() | Home > Technical (L322) > Front Seat Removal, Dissassembly and Heated Seat Repair |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Tried this today, probably just made it worse!
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Cool, glad it was useful |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Im just tackling this job now and I’ve found a broken pair of wires. I can’t see the rest of them as they disappear into the seat squab.
Only thing I can suggest is removing the seat cover from the squab to see if you can find the other end of the wires. This is assuming the part that is cut is the part that connects to the heater element.
They haven’t been cut. I think they have been severed inside the seat, possibly wear or caught on the metal frame.
JohnJ Member Since: 22 Apr 2016 Location: Varese Posts: 41 ![]() ![]() ![]() |
Hi, thanks for the write up
no! impossible, i tried. 2011 Vogue 4.4 Santorini black
I managed to remove the seat, change the seat cover that was ripped. Replug all connectors, refit the seat, and connect the battery.
The most likely place for an electrical failure will be the switches or the connectors I would have thought. Can you pull the switch panel with the seat in place and go through the cables with a meter checking for continuity? Also do the same with the connectors you can access?
thanks, in the tight space under the seat i tried poking all cables but no results,
magically when i went to start up the car to drive to the indie, the seat would move. Now i dont know if it was the sun and the temperature helped because this morning it was -5 and it was not working and now is +5, maybe the plastic cables got more flexibility and made better contact. In any case I took the opportunity to slide the seat back and forth to remove the bolts to remove the seat and then check the cables.
Thxxx Member Since: 09 Nov 2021 Location: Truro Posts: 7 ![]() ![]() ![]() |
Resurrection of the praise for this post, thank you so much for detailing it out so well, and providing a solution. Mine was exactly the same, the grey wire had come off the element, so some solder, shrink wrap and putting back together has done the trick. For anyone else trying this if it seems like there is no element, keep digging on the right hand side (at least mine was) of where the wire ends, it will be there somewhere.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 781 ![]() ![]() ![]() |
andyrosehome Member Since: 06 Jan 2018 Location: South Wales Posts: 14 ![]() ![]() ![]() |
Hi folks. I know this is a fairly old string but it is so useful that I felt I should add an update to my addition back in 2018 whilst still paying homage to mm289 who created the original how to in the first place. I used this brilliant write up again yesterday on my driver’s seat after the heated seat stopped working, indicated by my heater lights coming on for a few seconds when selected but then going out again. I would add a note of caution that removing the seat leather and foam is not to be under estimated but if you are reasonably handy then you can save yourself a lot of money especially if you want to get your heated seat element fixed for very little outlay. This is a long, labour-intensive job which took me 9 hours in total so be warned, but there is nothing particularly difficult.
