Home > My Range Rover > My opinion on my 1st week of having my L322 |
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 |
I've had my L322 delivery back to me after it being away for a few weeks. Happily it now starts on the button and can spend a few days without use without the battery going flat, so all good on that front.
23rd Nov 2021 11:40pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 682 |
get used to 'riding' the L322 rather than driving it.
25th Nov 2021 8:08am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3067 |
I've always thought that the 6 piston Brembo brakes do a good job of stopping the Range Rover and have never once felt underwhelmed by them. I've only ever driven them when fitted with genuine discs and pads though.
25th Nov 2021 12:29pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3187 |
Until I had a gearbox serviced I had the feeling that the gearbox was still driving the wheels when I took my foot off the accelerator and braked which made braking in the initial stage much less effective. 2012 TDV8 Vogue (L322) |
25th Nov 2021 1:16pm |
Cheers guys, I have taken your advice .... mostly as being without a big tank for a year has required recalibrating my brain
6th Dec 2021 12:23am |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
I'm a little bit surprised reading these experiences, perhaps they are related to what options the l322 has...Mine is a 2010 5.0SC Autobiography...We used to have a Mercedes-AMG GL, the x166 so slightly newer than your x164 with everything on it from air suspension with auto bolstering seats and side wind assist etc...
6th Dec 2021 7:52am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
If no evidence of main gearbox oil has been changed then get it done. Megaflush is what I recommend as it changes all the oil but only take it to someone who knows what to do.
6th Dec 2021 8:05am |
I'd get a simple gearbox service at an automatic specialist and also get them to diagnose any issues you have. A service will change enough of the oil to make a good improvement and from what I researched is a lot cheaper than a 'megaflush'. If a normal service doesn't fix it it's likley something more serious than the fluid but these 8sp boxes are very reliable. + 1 on getting the fluid in the transfer box and diff's changed as well at the same time. 2012 TDV8 Vogue (L322) |
6th Dec 2021 11:08am |
Tight is not the word My Cayenne and GL both fitting in the garage as long as I folded the mirrors in at when they reached the garage entrance with me hanging out of the window to ensure I was lined up properly, The L322 wont fit as the wing mirrors don't fold enough. I recall that the GLs mirrors were a lot smaller and folded fully against the glass. I am currently pondering having garage doors bolted to the front of the garage to free up 4-6 inches for that's for another time.
7th Dec 2021 2:28am |
Next time try the x166 onwards from the GL. That was a significant change to the x164, and if fuel consumption is of importance to you then Mercedes's 350d bluetec is on a different planet compared to the 420 or the Range Rover versions. Gearbox flush it is, possibly with a remap of gearbox, pedals and engine |
7th Dec 2021 7:17am |
I do like the X166 but the lack of the V8 diesel puts me off having one for now. I had basically the same engine in my Jeep Commander and I had that remapped with a GDE HOT tune, for 255 bhp and 455 pounds of torque.
8th Dec 2021 12:32am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i get what you mean by the handling mine had several issues
8th Dec 2021 8:30am |
I found out that all the tyres were at least 10 psi down ! Now I've got them to the right pressures I'm happy enough with the handling and it no longer wanders drunkenly around, so no need to rush and get the tracking done.
17th Dec 2021 11:33pm |
