Home > Technical (L322) > EGR’s - Throttle Bodies - Turbo’s : And how they work. |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 |
There is no waste gate - the turbo is variable vane. |
18th Nov 2021 9:24pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3196 |
The waste gate is only open under boost ( overboost) so won't be a bypass route around a seized turbo. Can you pull the intake hose of the turbo inlet and see if you can spin the blades? 2012 TDV8 Vogue (L322) |
18th Nov 2021 9:28pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1750 |
It's 99% a failed LH turbo Until you remove the downpipe, or intake pipe, your not going to know Same as I said on your other thread... |
18th Nov 2021 10:16pm |
Kevhdkent Member Since: 27 Oct 2021 Location: Kent Posts: 69 |
Thanks Mikey, that’s what I wanted to know.
19th Nov 2021 6:58am |
