Home > In Car Electronics (L322) > TV tuner / boot modules help |
nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 68 |
I think I would start with a IID GAP diagnostics tool. It's a bit expensive (like £400 ish) but I've found it to be worth its weight in gold as it checks virtually every system within the RR. I know it checks the TV system as I had a fault on mine which identified an antenna fault.
17th Nov 2021 5:02pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
The Workshop Manual, inc wiring diagrams is downloadable from the Wiki…. Top right….
17th Nov 2021 6:14pm |
Dean_C Member Since: 30 Apr 2021 Location: Lancashire Posts: 41 |
Have you tried tune channels in? |
17th Nov 2021 7:27pm |
bigben Member Since: 12 Nov 2021 Location: Northampton Posts: 17 |
I have tried automatic tuning which I assume should just work and manual which lets me change channels but finds nothing
17th Nov 2021 7:36pm |
OK I found some other images on the web which explained lots.
17th Nov 2021 8:22pm |
This is mine if it helps, though I do have RSE, but imagine TV wiring is the same….
17th Nov 2021 9:00pm |
That is brilliant thank you. It looks like I have all the antenna plugged into the right places (I have also checked the RHS antenna and it is per the workshop manual)
17th Nov 2021 9:38pm |
I’m not entirely sure, but won’t the TV option disappear from the menu if the module isn’t working? I know it used to on the early L322’s with BMW based iBus systems. Totally different to ours I know.
17th Nov 2021 10:02pm |
OK progress to report. After checking all the antenna cables were in the right place I gave up and went to bed. This morning I started my drive to work and by the time I was about a mile up the road I had TV reception. Seems my driveway is not in a strong signal area, no doubt not helped earlier on by at least two of the antenna not being connected.
18th Nov 2021 9:01am |
That’s good. I find I have to sometimes retune mine when I stop in a different area.
18th Nov 2021 10:32am |
To add a conclusion to this thread I was cleaning my other L322 in preparation for selling it and tried the TV button, assuming it was analogue, only to be greeted with a perfect picture. Had the car many months now and had never even bothered to see if it had a digital tuner!
20th Nov 2021 1:42pm |
