![]() | Home > In Car Electronics (L322) > TV tuner / boot modules help |
nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 69 ![]() ![]() ![]() |
I think I would start with a IID GAP diagnostics tool. It's a bit expensive (like £400 ish) but I've found it to be worth its weight in gold as it checks virtually every system within the RR. I know it checks the TV system as I had a fault on mine which identified an antenna fault.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
The Workshop Manual, inc wiring diagrams is downloadable from the Wiki…. Top right….
Dean_C Member Since: 30 Apr 2021 Location: Lancashire Posts: 41 ![]() ![]() ![]() |
Have you tried tune channels in? |
bigben Member Since: 12 Nov 2021 Location: Northampton Posts: 17 ![]() ![]() ![]() |
I have tried automatic tuning which I assume should just work and manual which lets me change channels but finds nothing
OK I found some other images on the web which explained lots.
This is mine if it helps, though I do have RSE, but imagine TV wiring is the same….
That is brilliant thank you. It looks like I have all the antenna plugged into the right places (I have also checked the RHS antenna and it is per the workshop manual)
I’m not entirely sure, but won’t the TV option disappear from the menu if the module isn’t working? I know it used to on the early L322’s with BMW based iBus systems. Totally different to ours I know.
OK progress to report. After checking all the antenna cables were in the right place I gave up and went to bed. This morning I started my drive to work and by the time I was about a mile up the road I had TV reception. Seems my driveway is not in a strong signal area, no doubt not helped earlier on by at least two of the antenna not being connected.
That’s good. I find I have to sometimes retune mine when I stop in a different area.
To add a conclusion to this thread I was cleaning my other L322 in preparation for selling it and tried the TV button, assuming it was analogue, only to be greeted with a perfect picture. Had the car many months now and had never even bothered to see if it had a digital tuner!
