Home > Technical (L322) > FBH setting to pre heat the car
mjdronfield
FBH is fitted as standard on all diesels as the diesels are more efficient than petrols so generate less heat and so take longer to warm up….
It was an option on the petrols I believe, but not many people chose it.
You may be lucky and have it, but I imagine it’s a faff to retrofit.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #611899 7th Nov 2021 12:14pm
Dean_C
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Just to recap:-
When activating the climate control via radio, I don’t get any airflow through any vents. Doesn’t matter if I choose heat or vent. The led on fan speed flashes & at the start of the cycle can here actuators moving for around 20 seconds but that’s about it.
All the fan speeds work when using the dial with engine running normally.
Anyone else had this?
Post #612716 15th Nov 2021 1:47pm
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I have exactly the same issue. It'll come on at the preset time. The light on the fan control will flash as noises happen for about 10 seconds or so then it all goes dead. Can't select it manually on the screen either as it then goes greyed out. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #612726 15th Nov 2021 5:23pm
Dean_C
Hi Marty
Thanks for the info, good to know I’m not the only one with this issue.
Would be good to sort it before the winter weather sets in.
Hopefully someone will be along with the solution 🤞😀
Post #612730 15th Nov 2021 6:13pm
MartinD
My plan is to get the wabasto diag stuff and see what's going on. After that, God knows.
I've got mine going in tomorrow for a health check though so I'll add it to the list. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Audi..Mini..BMW..
Post #612732 15th Nov 2021 6:23pm
