Home > Technical (L322) > FBH setting to pre heat the car |
FBH is fitted as standard on all diesels as the diesels are more efficient than petrols so generate less heat and so take longer to warm up….
7th Nov 2021 12:14pm |
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 |
I have exactly the same issue. It'll come on at the preset time. The light on the fan control will flash as noises happen for about 10 seconds or so then it all goes dead. Can't select it manually on the screen either as it then goes greyed out. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
15th Nov 2021 5:23pm |
Dean_C Member Since: 30 Apr 2021 Location: Lancashire Posts: 41 |
Hi Marty
15th Nov 2021 6:13pm |
My plan is to get the wabasto diag stuff and see what's going on. After that, God knows.
15th Nov 2021 6:23pm |
