Home > My Range Rover > Crazy newbie. Sight unseen with inactive suspension 4.2 SC |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
I'll stick money on the temp being air locked. Mine done the same when I bought it, drove it 200 meters and it was in the thr red. Logic says a car won't get to 130° from cold in 200 meters. Just bear in mind these can be an absolute pig of a job too bleed up. It's also worth checking that the fan is engaging. Genuine thermostat only cost me £40 but I also done the pump and belts as they wasn't too much extra work. Bleed it up with water first and see if you can get the temperature stable. I know a lot of people will argue this but its cheaper then using coolant and loosing it. Once your satisfied its holding temp, you MUST empty it and do the process with the correct coolant.
8th Nov 2021 5:09am |
conor Member Since: 27 Aug 2021 Location: London / Ireland Posts: 146 |
That's great advice, thanks Allen.
8th Nov 2021 10:39am |
It's pretty much same as any car with the bleed procedure. You have a nipple on the coolant tank you have too undo and wait until it comes out as a continous flow. I done mine over a few days.
8th Nov 2021 11:48am |
Thanks @Bean19844
12th Nov 2021 11:36pm |
I do it with water the first time mate so you can make sure there's no leaks from any of your pipes as the coolant can get expensive. My old v8 took 8 litres but as it had a leak at the back I kept loosing the coolant and money so done it with water, found where the leak was and addressed that then refilled it with coolant |
13th Nov 2021 1:14am |
Quick project update..
15th Dec 2021 1:10pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
15th Dec 2021 1:23pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6719 |
Most of those look pretty explainable, although the airbag fault does worry me slightly.
15th Dec 2021 1:55pm |
We have... in fact. I was at this again last evening with a buddy. Turns out the brake line for the wheel by MC is leaking, not the actual MC, nor was it overflowing out the lid. I'll be getting the car up soon for a good look and inspect all the lines. The car sat for for 12-14 months, so that leak is unlikely to be the only one, especially because it is so close to the MC.
Yea they aren't bad really. The Airbag one is likely because the passenger door module has been removed, along with everything else on that door, for a repair prior to my acquisition. My thoughts were i'd just put it all back and clear the codes. See what happens after that.[/quote] |
16th Dec 2021 2:40pm |
Get yourself a gap iid tool mate. I had an airbag on my 4.4 for about 6 months. Didn't realise it was only on because the battery wasn't being fully charged as the alternator was faulty. That gave up so changed that and the battery the cleared the fault and its never come back.
16th Dec 2021 11:54pm |
Oh yea Bean..
17th Dec 2021 12:13am |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 391 |
Enjoyed reading the post and progress - good luck. With regards to Wing Mirror glass I used this company for my FF and very pleased with it and the service - https://www.ebay.co.uk/str/wingmirrorstore Gavin
17th Dec 2021 10:52am |
Alright you wonderful lot... i've finally gotten my hands dirty... let's see what we have on our hands heh!
29th Dec 2021 3:16am |
..Where were we?
29th Dec 2021 3:30am |
