Home > In Car Electronics (L322) > aux rca to front screen
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
hi if i use the bottom set of rca behind front seats to show on rear screens can you also see what you are watching on the front screen the same time or will i have to try and link it in some way thanks new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #612236 10th Nov 2021 7:10pm
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I've read somewhere (I forget where sorry), that the rear RCA aux can only be seen on the rear screens. 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #612287 11th Nov 2021 10:15am
mjdronfield
Yeah, that’s what I’ve got in the back of my mind.
Doesn’t really help if I look on mine as I have a 2011.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #612291 11th Nov 2021 11:13am
oggy
okay thanks for your input i am sure you will come up with something mr dronfield . reason i ask i have just got amazon fire stick with rca to hdmi cables and usb cable to run it . i no it will run on my rear screens . but it would be nice to have it on front screen also new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #612338 11th Nov 2021 6:36pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
replace useless tv tuner with some aftermarket AV input module.
Post #612345 11th Nov 2021 7:00pm
mjdronfield
https://www.fullfatrr.com/forum/topic54114.html 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #612348 11th Nov 2021 7:06pm
mjdronfield
https://www.fullfatrr.com/forum/topic18380...ont+screen 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #612349 11th Nov 2021 7:15pm
oggy
i new i could rely on you mr mjdronfield and you would come up trumps very knowledgeable site member many thanks oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #612351 11th Nov 2021 7:29pm
mjdronfield
You are more than welcome mate. My memory isn’t what it once was, but I know a few had tried this before. In an ideal world, we would be able to just add a “box” somewhere from a later model, but not in this case.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #612352 11th Nov 2021 7:36pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
I have a Chromecast working on the front and rear screens of my '11.
It wasn't easy to do. Needed to cut into the factory looms for the RSE system.
The audio works through the speakers but also works through the headphones independently.
It is all hidden away in boot.
There is a post with someone from the US but the RSE system is slightly different so their method doesn't work in the UK.
Post #612453 12th Nov 2021 7:39pm
oggy
hi jnc i was sent your upgrade by the link that mjdronfield found and only 10 min ago i was going to message you and you got back to me well i never any way many thanks for doing that . it does sound complex but i think i can do it from help from your self . when you have time could you help me to know what i have to get and may be some pictures of what units i have to tap into and detailed wire procedure i will have to do thanks jnc for your help i can give you my email if you would like to do it that way pm me new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #612457 12th Nov 2021 7:55pm
JNC
I will explain in more detail later but quick run down…
USB power feeds to nearside boot
HDMI to Av out
HDMI - Hdmi & optical
HDMI splitter
Optical splitter
Chromecast
You feed rear screens by using the aux in, but at the rse module.
Audio and video
You need to cut the video feed from rse to front screen - I added switch so I can easily switch to dvd/tv if needed.
If doing that I also need to unplug av line. I could add switch but unplugging is just as easy.
If I could get the correct plugs I could make a patch lead. But haven’t been able to find anything as yet.
Post #612461 12th Nov 2021 8:26pm
oggy
okay thanks very much no rush at all oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #612465 12th Nov 2021 9:09pm
