![]() | Home > Maintenance & Mods (L322) > Rear wheel bearing 2011 tdv8 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4324 ![]() ![]() ![]() |
Have a strange wind tunnel like noise from drivers side....
Wasn't the wheel bearing. Odd.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35507 ![]() ![]() |
lets hope its an easy fix Rob...frustrating when its not obvious.. ... - .- -.
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 ![]() ![]() ![]() |
Dr Rob, are you sure it’s not one of the bushes? I had a similar issue on the SC and I replaced the bearing but it didn’t get rid of the drone but then I replaced the top rose and bottom bush and it’s been fine since.
Thanks for all the pointers.....will get there in the end! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 ![]() ![]() ![]() |
Someone will no doubt correct me if I'm srong, but I recall early L322's being fitted with, I think, Goodyear Wrangler tyres and it was found that when part worn they generated a noise not unlike a worn wheel bearing. In the US I believe tyres were often replaced under warranty for this issue (not in the UK obviously!). in 2007 I had a 2003 M62 engined L322 with Wranglers and it did indeed make a noise like worn wheel bearings on part worn tyres. By this time LR were fitting Pirelli Scorpion as OE, so I replaced with these and no more issues. Drives:
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
I sometimes have a similar noise. Turn on air recirculating and goes away. |
It's coming from outside and not through the vents. I've heard a whistling noise before through vents though. Totally different. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
John Which bits did you replace? https://www.advancedfactors.co.uk/rear-hub--carrier-289-c.asp Parts ending "260" and "644"? ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Dr Rob,
AutoB2018 Member Since: 09 Feb 2021 Location: Surrey Posts: 7 ![]() ![]() ![]() |
Have you tried adjusting the tailgate spoiler? I had to remove mine to fix wiper arm, refitted and had whistling noise after 60mph, adjusted to make sure even gaps on either side and hey presto no noise. Worth a try ? |
Noise is there from virtually 10mph upwards.
Disc is a tad too hot so new caliper time. Could even be source of noise...wasn't the bearing. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Callipers were fine. Pads were poor so changed for TRW ones.
