Home > Technical (L322) > Time Delay --is it Normal |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1653 |
The camera turns off when moving fwd over 11mph.
8th Nov 2021 4:57pm |
Yes that’s normal.
8th Nov 2021 5:15pm |
Old Barty Member Since: 05 Sep 2021 Location: Suffolk Posts: 21 |
Well Thank you both, Gentlemen --- That's the first bit of Good News i have had, Let's hope it's onward and upwards
8th Nov 2021 5:21pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
That's a sticking caliper old boy |
8th Nov 2021 7:20pm |
I’d agree with the above diagnosis. They do suffer from this. Wheel bearings do it too, but you might hear that or be able to feel play in the road wheel.
8th Nov 2021 8:03pm |
Thanks Guys, It's a strange one -- It's happened twice now at different times -- Today when it cooled down, I drove it under the carport and took the wheel off and it was as free as a bird. The 2 slider pins are both free and I could push the piston back fairly easily and the pads are nice and free However when I pressed the brake pedal again and released it, the disc was as tight as , so the caliper would be my first choice. I was wondering about the wheel bearing as there is a bit of a hum at 60+ , can't make up my mind if its shot or it's just road noise. Other than rocking the wheel I don't know an easy way to check . |
8th Nov 2021 8:39pm |
