Home > Technical (L322) > Cannot pair fob for Timed Climate Control
hlarry
I have a 2011 5l s/c. The timed climate control is working when set up from the dash but I can't seem to manually start it using my fob. I tried re-pairing the fob by pulling the 5 amp fuse from slot 16 in the fuse box on the right at the rear, replacing it and pressing the OFF button on the fob within 5 seconds for at least 1 second, but I still only get a flashing red light on the fob. I have also changed the battery on the fob.
What I have also noticed is that on the time climate control screen on the dash both "Manual Heat" and "Manual Vent" are greyed out. I wonder if this is because no remote fob has been paired.
Any help to get the TCC working before the weather gets worse would be appreciated.
H
Post #611877 7th Nov 2021 9:15am
Weegie
It's a long time since I did it but I remember when I tried pairing the fob on my Td6 I had to unplug the power lead to the unit. Pulling the fuse didn't work but removing the power did for some reason.
Worth a try anyway. John
GAP iiD BT
Post #611880 7th Nov 2021 9:34am
rjff
I'd go with Weegie on the fob paring.
The screen greyed out is likely due to you having the "ignition" on. Open up the car and turn on the audio with the button in the centre of the volume (left hand) knob. Go to the home screen, select timed climate and the manual touch buttons should appear.
Battery voltage is king for the FBH to operate correctly.
HTH Cheers
Richard
Gap IIDBT
Post #611884 7th Nov 2021 10:00am
Pjtaroni
Is that fob definately the correct one? I got one for mine the same as yours but wouldn’t pair, got a different type off someone on here and that paired first time! Maybe worth a search…
Post #611944 7th Nov 2021 9:32pm
hlarry
Many thanks for the suggestions.
Rjff - you are quite right. When I accessed the climate control screen without the ignition on, the two touch buttons were not greyed out.
Weegie - which unit did you unplug the power lead from?
Thanks again.
H
Post #611979 8th Nov 2021 8:39am
Fox889
The fob is either a T91 or T91R, my FFRR didn't come with a fob so I bought one off fleabay only to find it didn't work.
Mine was like yours ON/OFF on the fob, the one that worked for mine ['12 plate] was ON/heat symbol.......that's possibly the reason yours doesn't work......emphasis on the word 'possibly'.
Hope this helps. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
Post #611983 8th Nov 2021 8:53am
Weegie
It is the power feed to the receiver. Just unplugs and is pretty obvious when you look at it. Certainly in the earlier models. It is just a little awkward to get to as it is tucked in behind some other bits in the right hand side cubby hole.
It is marked as T90 or T91. John
GAP iiD BT
Post #611988 8th Nov 2021 9:34am
hlarry
Thanks for getting back.
Is this the receiver - I removed fuse 16, unplugged the power and aerial connection to this receiver before reconnecting both but unfortunately the fob was still not working and only flashing red when I pressed the OFF button (or ON button subsequently).
I don't really want to get a new fob unless I am pretty sure that is where the problem lies!
H
Post #612138 9th Nov 2021 5:19pm
Matt Buckland
United Kingdom 2017 Range Rover Autobiography TDV6 Santorini Black
It might be that your vehicle battery is slightly down on charge, or even insufficient fuel in tank. Checks are made to ensure that the battery can deliver enough cranking power after a 20 minute FBH cycle and that there is sufficient fuel. If either conditions aren’t met, the FBH fob will flash red and not fire up from the remote.
Post #612142 9th Nov 2021 6:03pm
hlarry
Matt - I don't think that is the explanation as by coincidence I have just installed a new battery. There is also plenty of petrol in the tank.
Thanks for the suggestion, anyway.
H
Post #612154 9th Nov 2021 7:24pm
JayGee
Mine works! New battery and no need to pair it. 2012 TDV8 Vogue (L322)
Post #612317 11th Nov 2021 3:08pm
