Home > Technical (L322) > Cannot pair fob for Timed Climate Control |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3234 |
It's a long time since I did it but I remember when I tried pairing the fob on my Td6 I had to unplug the power lead to the unit. Pulling the fuse didn't work but removing the power did for some reason.
7th Nov 2021 9:34am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
I'd go with Weegie on the fob paring.
7th Nov 2021 10:00am |
Pjtaroni Member Since: 21 Aug 2021 Location: Loughborough Posts: 37 |
Is that fob definately the correct one? I got one for mine the same as yours but wouldn’t pair, got a different type off someone on here and that paired first time! Maybe worth a search… |
7th Nov 2021 9:32pm |
hlarry Member Since: 29 Jan 2021 Location: London Posts: 22 |
Many thanks for the suggestions.
8th Nov 2021 8:39am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 685 |
The fob is either a T91 or T91R, my FFRR didn't come with a fob so I bought one off fleabay only to find it didn't work.
8th Nov 2021 8:53am |
It is the power feed to the receiver. Just unplugs and is pretty obvious when you look at it. Certainly in the earlier models. It is just a little awkward to get to as it is tucked in behind some other bits in the right hand side cubby hole.
8th Nov 2021 9:34am |
Thanks for getting back.
9th Nov 2021 5:19pm |
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 55 |
It might be that your vehicle battery is slightly down on charge, or even insufficient fuel in tank. Checks are made to ensure that the battery can deliver enough cranking power after a 20 minute FBH cycle and that there is sufficient fuel. If either conditions aren’t met, the FBH fob will flash red and not fire up from the remote. |
9th Nov 2021 6:03pm |
Matt - I don't think that is the explanation as by coincidence I have just installed a new battery. There is also plenty of petrol in the tank.
9th Nov 2021 7:24pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3227 |
Mine works! New battery and no need to pair it. 2012 TDV8 Vogue (L322) |
11th Nov 2021 3:08pm |
