Home > Maintenance & Mods (L322) > NO power (not limp mode) idle at 500rpm - now non starter . |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
My take would be 3.6 litres of air moved every 2 revolutions (suck, squeeze, bang, blow 4 stroke). so we should have 100 x 3.6 litres per minute, which is 60 litres per second. 5 seconds cranking should have exhausted 300L of gas in the 5 seconds, remember diesel engines have wide open manifold etc. I feel it should have inflated the bag a bit, well, more than a bit. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
4th Nov 2021 7:59pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1750 |
Unless the turbo has collapsed, and is stopping the air from escaping down the exhaust system...
4th Nov 2021 9:32pm |
If you consider all the valves open or cam stationary, one piston moving up exhausting, another will be going down so the displacement would be small. Drop the EGR pipes off and then we will know as mickey said. I think we’re getting close now. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
4th Nov 2021 10:19pm |
Kevhdkent Member Since: 27 Oct 2021 Location: Kent Posts: 69 |
Appreciate all the input
5th Nov 2021 8:30am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1194 |
This is a great read and believe it or not I went to bed thinking about this and when I woke it was still on my mind--God I am sad But great fault finding and every input made with good intent---great forum! But what's nagging away at me is the quote above. The Engine never stopped, stayed at 500rpm until driver intervened, never to start again. It does not suggest major failure. 1 I Presume the throttle is a electrical/electronic? If this failed, surely the ECU will prevent a run away/or a sudden stop while running at speed (possible towing etc) and possibly at night for safety reasons? In such an event surely ECU will be programmed to ensure enough revs (500 rpm) to maintain system workability lights brakes suspension etc enough to enable driver to intervene and coast to a safe place, then when stopped prevent further start. 2 Also--Surely the crank position sensor will be in the same circuit (another input to same ECU), as it measures engine speed, and if that failed in use while driving, the same program in the ECU would do the same. So the ECU would monitor these 2 inputs among other things, and when something strange happens it will be programmed to have such a response? Has any member experience any of this 2 failures while driving? Interesting to know what experience you had Now I can go back to bed 2018 SE SDV8 4.4 Byron Blue |
5th Nov 2021 9:05am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
The throttle is referred to as a driver demand sensor, to which the ecm reacts as it has been programmed. The throttle doesn't have any direct control.
5th Nov 2021 9:45am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
Agree with GraemeS. I had a Ford Explorer that either would start or wouldn't. Once started it was fine. One day it wouldn't start. RAC came out and just wiggled the electrical connector on the crankshaft sensor and it started!! So mine wasn't even the sensor. Cleaned connector and no more trouble. Worth trying. |
5th Nov 2021 11:59am |
It does have direct control if it fails. Extract from WSM "The APP sensor (Accelerator Pedal Position sensor) signals are checked for range and plausibility. Two separate reference voltages are supplied to the pedal. Should one sensor fail, the other is used as a 'limp – home' input. In limp home mode due to an APP signal failure the ECM will limit the maximum engine speed 2000 RPM. The APP sensor has two potentiometer tracks which each receive a 5V input voltage from the ECM. Track 1 provides an output of 0.5V with the pedal at rest and 2.0V at 100% full throttle. Track 2 provides an output of 0.5V with the pedal at rest and 4.5V at 100% full throttle. The signals from the two tracks are used by the ECM to determine fueling for engine operation" The ECM monitors the outputs from each of the potentiometer tracks and can determine the position, rate of change and direction of movement of the throttle pedal. The 'closed throttle' position signal is used by the ECM to initiate idle speed control and also overrun fuel cut-off. So we can see if 1 track fails, then limp home allowed at 2000rpm. But what if both tracks fail and failed at zero voltage (broken wire/bad connection) Do you think it would allow limp home then? I wonder in this scenario, the ECM has a built in safety program to go to idle and not allow a restart? Interesting info about your experience regarding crank sensor, (Engine stopping and not starting) but this does not explain why this engine was still running at 500rpm and looked like it would continue at that rpm, until the driver shut it down. 2018 SE SDV8 4.4 Byron Blue |
5th Nov 2021 12:57pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 731 |
I stand corrected (partly), my mental arithmetic is slipping, 3.6L x 100 = 360L/min MAX? = 6L/second = 30L per 5 second crank MAX assuming no leaks/losses which isn't very likely, so even less chance of blowing a bag up? All the more reason to follow the guidance of the likes of Mikey and ignore the rest of us! |
5th Nov 2021 3:21pm |
You have changed your tune since this post any reason 2018 SE SDV8 4.4 Byron Blue |
5th Nov 2021 4:38pm |
Yes - I thought I'd sit quietly then look for the "smug tw@" emoji if it turns out to be the sensor
5th Nov 2021 6:12pm |
The fact that the motor continue to idle at low rpm for some minutes before I turned the ignition off is something I have to keep highlighting. It eliminates most of the “catastrophic” suggestions such as snapped camchain etc. |
5th Nov 2021 7:03pm |
That’s my plan, but Due to my working on a construction site, this time of year that’s dawn to dusk, I’ve been gleaning all the info and suggestions I can. So tomoz the work starts. Basically I’ll be looking at those items which are most accessible. Not helped by it being sat half on the road outside as I can’t move it onto the drive or into the shelter of the garage 😩😩 |
5th Nov 2021 7:11pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8189 |
Good luck Pete
5th Nov 2021 8:39pm |
