![]() | Home > Maintenance & Mods (L322) > NO power (not limp mode) idle at 500rpm - now non starter . |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
All of the suggestions of crank sensor, throttle position etc are all negated because it doesn't fire with easy start. Using easy start doesn't need any electronics, if the engine ingests it and it has compression it will fire, this engine doesn't. With this mind either there's something wrong with the induction - blocked exhaust would prevent induction due to back pressure or valves not working correctly may prevent induction and likely reduce compression.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
No, they are right at the back of the engine |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 751 ![]() ![]() |
I would agree with the easystart theory on an older vehicle but I suspect that this isn’t the case with modern stuff. They are packed with “safety” features including ways to shutdown the engine if it believes something is wrong.
Kevhdkent Member Since: 27 Oct 2021 Location: Kent Posts: 69 ![]() ![]() |
Thanks Mikey,
So that’ll be these 2 then ? Presumably have to break them just enough to let the air out/in unhindered? Last edited by Kevhdkent on 6th Nov 2021 4:15pm. Edited 2 times in total |
No electronics are controlling the valves so therefore compression should bve there, if there is compression and easystart it has to fire. There are some butterfly's in the inlet side which can close to shutdown a runaway engine but the OP has stated theyre open, even if they were closed you still get the odd firing of cylinder whilst cranking, the OP has said he feel suction on the inlet side so it should be sucking the easystart in there. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
It’s Started ! See above 👆 👆👆 |
Thats great news, I missed that when I posted. So, blocked exhaust, every day a school day! BMW i3 Electric Car
Can you shed any light on where to go now ?
Blocked exhaust...
Okie dokie.
