Home > Off Topic > hour rates by various makes/garages
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
forget it Laughing
Post #61124 20th Apr 2011 11:22am
nick h
ll
Post #61130 20th Apr 2011 12:16pm
dan_uk_1984
nick h wrote:
i had to delete independents from my original question because they simply do not have the 'cover' that a main dealer has!
When you've taken your car to a dealer to have them diagnose a problem for the "umpteenth" time and every time they charge you £200 for the privilege of their "expertise" you will see that the "cover" you get from them is actually very poor.
Compare this with an independent who charges 30-50ph, works on the cars every day AND has to rely on satisfied customers AND repeat business (two areas where a LR dealer doesn't give a damn)
I know from experience which I am more likely to get a better solution with. My car and its previous owner is a perfect example. 3 or 4 trips to a main dealer to get a knocking noise located and sorted. After replacing various components they still hadn't fixed it.
My indy spotted the worn anti-roll bar links, and changed them over for under £50 inc parts and labour.
A decent indy will have the same computer LR garages use so will be able to do exactly the same work.
After all - do not forget that your local Land Rover Dealer is NOT Land Rover. They are a private company who have a deal with LR UK to sell their cars, nothing more.
Post #61137 20th Apr 2011 12:52pm
good points there dan. Thumbs Up ... - .- -.
Post #61143 20th Apr 2011 1:47pm
nick h
nick h wrote:
ll
very fair point Dan
BUT
if you have no decent independents then you are stuffed - back to main dealer?
with the grand cherokee i had a great local independent - without him i'd have been stuffed
the landrover independent in chesterfield could not see the car for 10 days - i accept the cost of running/owning a top marque having previously owned porsche/ferrari - but i do not unreasonably expect decent service?
Post #61574 26th Apr 2011 11:14am
