Home > General (L460 2022) > New 22MY FFRR due to be unveiled next week! |
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 716 |
Yes, I think that’s how it works. The app allows you to start the cars’s engine remotely and it will heat/cool to whatever was set. The option is the FBH.
31st Oct 2021 12:46pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 923 |
Indeed this option is a FBH.
31st Oct 2021 12:54pm |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 903 |
Sorry, can't agree with that. It is both. The Range Rover has 4 models, Evoque, Velar, Sport and FF. The model name and trim for FF is Vogue,SE or Autobiography and SV. What do you call it, if not a Vogue? If you call it a Range Rover it could be any one of 4 All LR cars from 1984 2021.5 Vogue SE D300 Carpathian Grey 2018 Vogue SE British Racing Green GONE |
Although it’s less powerful than the outgoing SVA the performance is better. But, for sure, there will be more powerful versions of the V8 in the pipeline. LR never gives us all it has got in one go. They will keep adding and changing every year or two to keep the interest up. What is odd is that there is no difference between SV and Autobiography other than some better leather and a few bits of trim. Difficult to justify a large premium for this alone. |
31st Oct 2021 1:00pm |
That’s not correct.
31st Oct 2021 1:05pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2571 |
Always found referring to the actual model as a “Vogue” very annoying. |
31st Oct 2021 1:31pm |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 769 |
I agree with those who don’t like it being called a Vogue, as that’s the base trim level not the model name, t’s simply the Range Rover. Or maybe THE Range Rover
31st Oct 2021 2:22pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Vogue is an international publication but more to the point here, a registered trademark JLR can not use in the USA.
I would argue it is simply to future-proof the dashboard design when they come up with a larger screen, as it would not require any mods to the actual dashboard, just bolt on a larger screen. Also, it is, I assume, to try to mimic the Tesla Model S and Y minimalistic design. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
31st Oct 2021 2:28pm |
It clearly isn’t “laziness”, that much is certain. |
31st Oct 2021 3:05pm |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
Agreed. The V8 Autobiography is probably the one to buy. No need to go SV. P.S: Note to moderator: Perhaps we could have a dedicated L460 section now that the new model has been launched? |
31st Oct 2021 3:43pm |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 283 |
For what it’s worth, whenever I’m asked (do you mean Sport, Velar etc) , I say “no it’s just a standard Range Rover” 2016 SDV8 AB |
31st Oct 2021 5:43pm |
I understand where you are coming from.
31st Oct 2021 5:55pm |
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 229 |
Didn't the Vogue spec used to be the top of the FF range?
31st Oct 2021 6:34pm |
Autobiography used to be around from around 2005 I believe…initially as a derivative which was highly personalised via SV. |
31st Oct 2021 6:36pm |
