Home > General (L460 2022) > New 22MY FFRR due to be unveiled next week!
Page 42 of 46 <123 ... 414243 444546>
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I think Autobiography was launched with the P38 as a personalisation programme, I still have a brochure from when I owned my 4.6 HSE in the 90’s. Autobiography has then become a trim level from L322 onwards. SV now caters for what Autobiography used to stand for.
Post #611210 31st Oct 2021 6:58pm
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
I might be wrong, but I'm pretty sure that the "Autobiography" name did get something of a break from all early L322 models (2002 to 2009).
I can only recall SE, HSE and Vogue models, with Vogue SE being the range topper.
After circa 2010 it did begin to reappear on the 5.0 Supercharged model - I say reappear, because as CSK also points out, I'm sure some of us can still remember the P38 4.6 Autobiography
Post #611223 31st Oct 2021 8:08pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Autobiography wrote:
Indeed this option is a FBH.
It’s illegal to have the engine running on a road without being occupied and there was a case of a police fine on another forum. It’s fine for the FBH.
Does the new defender not have an option to remote start? I’m sure the Powerful UK petrol model has that.
Post #611229 31st Oct 2021 8:45pm
Philip
Autobiography started in 1993.
Post #611234 31st Oct 2021 9:22pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
My Defender has both on the P400. However the FBH was a cost option and can’t be controlled with the app (just the separate fob). The engine can be started with your phone.
Post #611250 1st Nov 2021 7:24am
Martin2
Mine is exactly the same (FBH with the Fob, remote start to heat or cool through the app) MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #611252 1st Nov 2021 8:05am
Autobiography used to have a different meaning. I'm not sure when it became a trim level / options package.
It used to meant some sort of special order, so even if you ordered the base of base models & has special paint, then it was badged AB.
A mate of mine had a 2003 AB because he wanted black paint and a black interior and that wasn't an option at the time. I can't remember whether it was just in combination or whether one of them wasn't available as standard.
Post #611254 1st Nov 2021 8:21am
Autobiography
Would be great if the FBH can finally be controlled from the app too. I can’t see any benefit on a cold day from starting the engine rather than the FBH.
Except…this ‘heated seat’ hack only works from starting the engine…
For those with hot stone massage seats, set this to ‘auto massage’ and then the hot stone massage still comes on when the engine has been started from the app so you’ve got a warm seat to jump into!
Post #611255 1st Nov 2021 8:23am
aja500
Thank you all for the correct info regarding the FBH.
So in short, to be able to set the precise temperature in the car, you need the Cabin Pre-Conditioning, otherwise you're just starting the engine via the App and as the engine warms up, returning the car to the temperature setting which the car was left at - Is that correct?
Just going back to what somebody mentioned about starting a car and leaving the engine on before your journey can cause engine wear, TBH I always let my engine warm up for about 10 minutes prior to driving the car.
This is because I always remember a TV advert for Castrol GTX, where we were told that 75% of engine wear occurs when an engine is cold!!
This wasn't the exact advert, but was similar - Enough to worry me at least:
Post #611257 1st Nov 2021 8:34am
Martin2
I'm fairly sure that letting your car idle to warm up for 10mins isn't the right thing to do, not with a modern vehicle that doesn't need the carbs warming through anyway. Better to let it warm up more quickly by driving it, but doing so gently until it is up to temperature. MY23 Panamera E-Hybrid
Post #611259 1st Nov 2021 8:51am
aja500
You might be right Martin - I suspect technology in this respect has probably moved on, unlike me Very Happy
Post #611260 1st Nov 2021 8:55am
Martin2
Sounds like it! Laughing
The technology of cars has come on in leaps and bounds in the past couple of decades, meaning that leaving your car engine ticking over first thing is now not needed - and sometimes harmful to your motor.
In fact idling actually prolongs the warm-up period, Road&Track told the Manchester Evening News .
The conventional wisdom that you should idle your car up to operating temperature comes from the days of carburettors, which needed several minutes of idling to get to an operating temperature where they'd run smoothly.
Generally, cars do not have this any more.
Why you don't need to idle your engine
Engines are now fuel injected and a better approach is to simply drive away immediately. Gentle driving warms the engine quickly without putting too much load on it before reaching operating temperature.
Can idling cause damage?
Yes, idling for too long on a cold day can cause engine oil dilution
Post #611261 1st Nov 2021 8:55am
aja500
That's actually really good to know, thanks Martin Thumbs Up Thumbs Up
Post #611262 1st Nov 2021 9:03am
Phil.
I had a MY16 AB with the FBH and you could control it via the App and fob. You couldn’t switch on the engine remotely at that time.
I then swapped for a MY17 with the FBH and could only use the App to switch on the engine and the fob only for the FBH (as is the case now). A step backwards in my opinion, which I reported on here at the time.
From experience the FBH will warm the interior and clear the front screen in the coldest of conditions. It also warms the oil which helps the engine warm up more efficiently. If you’re doing early starts on winter mornings it’s a must have. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #611264 1st Nov 2021 9:06am
Chalky
The Remote App for my car has a "Target Temperature" which you set, it then starts the engine for 30 mins max. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #611269 1st Nov 2021 9:45am
