Home > Technical (L322) > Rumbling and vibration
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Drove the old girl 95 miles into North Norfolk yesterday and noticed there is a vibration through the car at 40-65 mph and it doesn’t feel like it’s coming from any corner in particular.
Engine speed doesn’t seem to make any difference but car speed does a bit.
I’m thinking it’s my prop shaft bearing so when I get home I’m going to have a look and see if it’s shot.
Will report back on here what I find Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #610854 28th Oct 2021 8:16pm
mjdronfield
Sticky rear brake callipers are a fairly common issue. If a wheel is hotter to the touch…. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #610856 28th Oct 2021 8:20pm
Caesium
Thanks for the heads up. I’ll check them too Christian.
Current Cars
2019 BMW X4
or
Post #610866 28th Oct 2021 8:52pm
Caesium
Prop shaft is out, anyone know how to separate the halves that are bolted together in the UJ?
They seem pretty well stuck and I don't want to hammer it anywhere or I'm concerned it will affect it's balance Christian.
Current Cars
2019 BMW X4
or
Post #610973 29th Oct 2021 5:19pm
Caesium
I absolutely cannot get these parts apart. Anyone for any ideas?
 Christian.
Current Cars
2019 BMW X4
or
Post #611034 30th Oct 2021 9:18am
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Maybe look in the WM page 283/284?
I presume the RR 2005/2010 have the same shafts, as yours have.
From the WM
The rear drive shaft is a 2-piece unit, supported on a central bearing due to its increased length. The rear drive shaft is connected to the transfer box and the rear differential via CV joints. These joints allow for angular deviations of the drive shaft due to acceleration and braking.
The front and rear drive shafts are not serviceable items and a failure will require the replacement of the complete drive shaft assembly.
FRONT DRIVESHAFT
Regards Piet
Post #611044 30th Oct 2021 11:44am
Caesium
Perseverance and an air hammer.
 Christian.
Current Cars
2019 BMW X4
or
Post #611054 30th Oct 2021 12:59pm
Piet
Good job done. Thumbs Up Thumbs Up
Post #611060 30th Oct 2021 1:45pm
Caesium
So following the propshaft centre support bearing replacement and subsequent discovery of sticking rear calliper, I've also refurbished both rear callipers with new pistons and seals and now my rear brakes are working as intended!
No rumbles and no vibration any longer. Bob on!
 Christian.
Current Cars
2019 BMW X4
or
Post #612218 10th Nov 2021 3:51pm
