Home > Technical (L322) > LHD Head Lights |
Deep Down Member Since: 06 Apr 2011 Location: Deux Sevres Posts: 104 |
Does any one know does the whole Lamp unit need changing to convert RHD to LHD head lights? |
19th Apr 2011 9:46pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
yours is 2003 so it has the square type light units and yep, you need new light units for lhd.. ... - .- -.
20th Apr 2011 8:22am |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi, my fault..i just took it you had 2006 lights,hence the adaptive reference V8 facelift Range Rover Autobiography 22" wheels.
20th Apr 2011 8:56am |
Do you not just flick the LHD/RHD lever over inside the lamp unit? |
20th Apr 2011 9:00am |
myvatn Member Since: 20 Oct 2010 Location: Munich Posts: 80 |
ours is a late 2003 RHD and you just have to switch (under the bonnet) the lamp unit to LHD to make it road leagl in mainland Europe |
20th Apr 2011 9:05am |
you can but it doesnt give a proper light distribution...thread on here somewhere re this.. edit..apparently the rhd lights point to the left and the switch just blanks the beam so it doesn't dazzle oncoming drivers. ... - .- -. Y. O. L. O. . |
20th Apr 2011 9:08am |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
It isn't a simple as that I suspect - If the car is a UK registered LHD spec car then to pass the UK MOT you have to have the right pattern of beam spread and that requires a set of UK pattern headlights - the little lever is only meant for temporary use like going touring in Europe. Friend of mine has a UK supplied / registered LHD RRS in Belgium. It was supplied with the correct LHD dipping pattern headlights. Last year he had to bring it back to the UK for it's MOT and had to buy a set of UK pattern headlights to pass the MOT, luckily I was selling my bling set with the LED's in them so he collected them, fitted them (took 5 minutes) went for MOT and passed! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
20th Apr 2011 9:19am |
Did buy a 2003, but as the gearbox gave in after 25km, he got it back. In the middle of doing a deal for a 2004 after they went to touch screen. Given up on trying to buy an LHD model in good condition for real money. |
20th Apr 2011 12:22pm |
there are these two on ebay but they are very expensive and only halogen, and before you ask ,no they cant be converted to xenon..
20th Apr 2011 1:45pm |
